Hello,
I just purchased a Monopoly with a color DMD. I want to take it out and install it in my Spiderman Black. The Ribon cable does not seem to be the same. Will this color dmd even work?
Hello,
I think if you go to colordmd.com and go to accessories. they have the cable kit for sam/whitestar. that should be what you need
Yes it will work. The large display board on the rear of the ColorDMD is your Monopoly display board. It stays with the game.
For Spider-Man follow the SAM installation instructions and use the existing 14-pin ribbon cable that’s in the game.
I have it installed. I downloaded the rom from the website. I followed the instructions and now my screen is blank.
Looks like my color DMD is a 1.3 version so it won't work on my Spiderman. I was told they work on all pins.
Spider-Man needs more memory on the colordmd controller board. You need 1.3b revision. The display is fine. The games colorized in the past year need the 1.3b board or newer chroma board, both of which have more memory. Maybe trade with someone that doesn't need the newer board or it will work just fine in monopoly.
Quoted from luvthatapex2:Spider-Man needs more memory on the colordmd controller board. You need 1.3b revision. The display is fine. The games colorized in the past year need the 1.3b board or newer chroma board, both of which have more memory. Maybe trade with someone that doesn't need the newer board or it will work just fine in monopoly.
Thanks.
This page was printed from https://pinside.com/pinball/forum/topic/color-dmd-question-3 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
