As the topic says. It arrived, it was easy to install (took about 5 minutes, 4 screws and a few cables) and it is really awesome. Even though it is an LCD, it does not look washed out. The images are very sharp and the blacks are black enough that you cannot notice it has changed to an LCD. It uses way less power than the plasma DMD also.
Even better, I had an old WPC 95 A/V board that was busted. It needed the HV section of the video rebuilt. But it was reworked before so it had no hope of being fixed. After installing the color DMD, I put that old board back in the machine and everything works great with it. The Color DMD does not need the HV output of the A/V board so the fact that those circuits are broken don't matter. So now I have a spare WPC95 A/V board and DMD left over on top of it!
