COLD CASE FILES: Aquarius Kickout Hole Scoring
(Topic ID: 216984)
By currieddog
9 months ago
  • 60 posts
  • 5 Pinsiders participating
  • Latest reply 84 days ago by currieddog
There have been 10 images uploaded to this topic. (View topic image gallery).
There are 60 posts in this topic. You are on page 2 of 2.
#51 8 months ago
Hi Rolf-It is a standard 1156 car bulb (US) = "Philips 1156 Standard Auto Bulb (Pack of 2) Philips brand miniature automotive lamp. 26.9 Watts and 12.8 volts. S-8 size and shape, single contact bayonet base."
#52 8 months ago
Hi currieddog
no luck - I visited the mentioned store - no answer like "Yeah - it is because ...". The people said "mysterious - aha - AC-Current - maybe kind of flash due to Hertz - or - or - or --- many "maybes" and when they started questioning the OHMs (1.5 to 2.1 Ohm) on the Aquarius-Relays - 1.5 Ohm is impossible - maybe 1.5 Kilo-Ohm: I stopped the discussion and asked "how about putting an resistor there (instead of the Test-Light)" - they adviced 8.4 OHM - 30 Watts. Hmm - maybe an 8.4 Ohm, 30 Watt resistor does the job - maybe - maybe not. For sure such an 30 Watt (!) resistor will cost a lot ...
I look in pinside at Your collection of pins - several Gottliebs - may want to buy (from PBR) an Gottlieb-A-9746-Coil as a replacement on the P-Relay - maybe with an new coil the problem vanishes ? - may want to buy an Gottlieb-A-9746-Coil when You are buying other stuff needed for another pin (?)
A lamp is good for maybe 2000 to 3000 hours --- when You mount the 24Volt-Test-Light (dim lighting) the life-span will be longer -
my suggestion is: Mount an Test-Light permanent - make an good documentation and live with the situation. I have no more ideas - I did ask experts in the store*** - there is nothing more I can do to help You.
experts in the store***: It is a store for Hobby-ELECTRONICS (making me an receiver or an amplifier or whatever --- it is not for EM-pins) --- Yes, they sell relays - to use in printed circuits --- such relays they know --- look here https://gfinder.findernet.com/public/attachments/40/EN/S40EN.pdf on page four - the 40.52 type (size about two sugar-cubes) --- I bought such relays 6VAC, 24VAC, 48VAC, 220VAC - nice handy, practical. See on page 9 "AC coil data" - 6Volt-Coil has 21 OHMs, 24Volt-Coil has 320 OHMs, 110Volt-Coil has 6900 OHMs means 6.9 Kilo-OHMs. So I accept when they question the 1.5 to 2 OHMs on 1970ies-pinball-relays.
Greetings Rolf
#53 8 months ago
Quoted from rolf_martin_062:
NOOOOO!!! Say it isn't so, Rolf!
I actually do have a new coil. I bought it a while ago, but then went back and forth about whether it should be changed. Might as well give it a try. Maybe a tiny break in the wire or something.
#54 8 months ago
Quoted from HowardR:
If you'd like a phone call, PM me some contact information.
Quoted from currieddog:
#55 8 months ago
Hi currieddog
I see no problem YOU have a permanent hooked-up LAMP on an relay --- I enjoy my Shangri La with an permanent hooked-up RELAY*** on a lamp --- rewarding me an Extra-Ball when the lamp lights-up --- see the JPG - it is very hard to get - when the red light below the text "Special" lights up: ALSO my RELAY*** pulls-in and I have gained an Extraball. See the wire to "my letter 'S' on the playfield" - a simple connecting wire to the tip of the lamp below the playfield.
RELAY***: It is an Finder-6VAC-Relay - see the link in post-52. Greetings Rolf
#56 8 months ago
Well this is odd: the new coil only reads .2 ohms. But it should be up around 1.6 or so, yes?
#57 8 months ago
Hi currieddog
have "old coil free of connecting wires" and have "new coil free of connecting wires" - then measure --- does the old coil has about 1.5 to 2 OHMs - and new coil has 0.2 OHMs ? Then I'd say: New coil is bad - buy another one. Greetings Rolf
#58 8 months ago
Well, after all that ... the coil (P). And the plate was fairly cruddy, too. And I used the one I had after chatting with Steve at PBR. Thanks to everyone who checked in, esp. Rolf!
5 months later
#59 84 days ago
So what was the eventual solution? Replace the P coil ?
#60 84 days ago
Yes, oddly enough. The new and old coils had the same ohm readings, but NOW IT WORKS CORRECTLY!!
$ 18.95
$ 149.00
Sparky Pinball
$ 46.99
Lee's Parts
$ 7,499.00
Operation Pinball
$ 48.00
$ 48.00
$ 89.99
$ 29.99
CzTV Mods
$ 1,000.00
Playfields
Pinball Playfields
$ 159.99
Third Coast Pinball
$ 15.75
Cabinet Parts
Tilted Pinball
$ 99.99
$ 9.99
$ 250.00
Great American Pinball
$ 39.00
The MOD Couple
$ 7,499.00
Gulf Coast Pinball, LLC
