I've adjusted the weights on this Cointaker Spike shaker motor to a 180 degree offset, and cranked all the bolts down tight (including the long screw between the sides of the bracket) but the motor is really rattly. What are some ways I can make it not rattle so much? Could I put some kind of foam or cushion between it and the bottom of the cabinet before screwing it down? Or is the rattle coming from the motor itself, and I'm just stuck with it?
