Bally Rock Makers 1968
Got one problem fixed but found another. There was a wire removed from the 3rd Coin Chute Re. On the coin door. When I reattached it and started the pin here’s what happens:
Start relay energizes and holds
Score motor starts, but does not stop
Score reel all set to zero
Coin Latch relay energizes but does not latch.
I can manually hold the Coin Latch plate in, which latches the Coin Trip plate.
The minute I release the latch plate the score motor runs, but the Coin Relay will not latch.
Hope this made sense?
I can add the schematic for this section if it helps?
Kickout
