(Topic ID: 248301)
Coin operation
By Gcoco35
2 years ago
  • 13 posts
  • 6 Pinsiders participating
  • Latest reply 1 year ago by LTG
#1 2 years ago
I flipped the switch the switch in the cabinet away from tournament mode, however the machine will still not except quarters. It just sits them back out. Is there something else I have to change in the setting or with the coin operators in the door? Thanks
#2 2 years ago
It would help to know what game you’re talking about. But in my experience, the only thing that intentionally prevents a game from accepting coins is when the maximum number of credits has been reached. On older games, the machine has a coil in the coin door to prevent the machine from taking more coins.
If that’s not the issue here, then it’s a mechanical problem with your coin mech. It probably needs to be cleaned and adjusted.
#3 2 years ago
Quoted from ryanwanger:
And even on top of that, in newer games, without the coin lockout coil, the mechs will STILL accept coins, you just won't be awarded any more credits. (With the exception of running an electronic coin mech that is connected to the games 'Coin Enable' input (for WPC at least.)
#4 2 years ago
Are the correct coin mechs installed for the denomination you are using?
#5 2 years ago
Sorry it's a 1994 gottleib rescue 911 machine. When I turn off tournament mode I see the credit 0 instead of free play on the screen. Coin ops are clean. It's like the coins are being redirected instead of falling all the way down to the collector.
#6 2 years ago
Quoted from Gcoco35:
Are there different screws and stuff that can be adjusted on the coin mechs? Unfortunately, it's like some sort of black magic that I can't help you with.
They could have been set up for different type of coin (or token).
#7 2 years ago
If the mechs are rejecting quarters, they might not be quarter mechs. Or, they may be too worn out to direct coins in the proper direction.
can you post photos? Maybe there's something we can spot.
#8 2 years ago
Gottliebs of that era used Coin Controls brand coin doors.
#9 2 years ago
#10 2 years ago
Your coin mechs are missing the "kicker/seperator" assembly. Without it, all coins are rejected. Also one coin mech is missing the mech hold down bracket.
#11 2 years ago
Quoted from KenLayton:
Your coin mechs are missing the "kicker/seperator" assembly. Without it, all coins are rejected. Also one coin mech is missing the mech hold down bracket.[quoted image]
Heck, it looks like the cradle is missing, too? At least in the close one?
5 months later
#12 1 year ago
Does anyone know the part number for the correct coin mechs? Thanks
#13 1 year ago
https://www.pinballlife.com/25-cent-standard-coin-mech.html
These will work fine. The two studs on each side, might have to be removed or moved to different holes. Three holes each side. This is a one minute thing, if needed.
