Quoted from jtreehorn:
Hi all. Just checking in to see if anyone has any info on the coin op breathalyzer I just picked up. Also, if you do, can you send me pictures of the two connectors that attach to the board? Thanks!
No but I do own a Boozelator. Gotta get some pics
I've always kinda wanted one of these. I'm afraid we would fail beating games and revert to beating this though. Hi score over here!
A bar I used to frequent had a coin-op breathalyzer hanging on the wall by the jukebox.
We put a chalkboard next to it so we could compete for high scores.
They are easy to "beat" in that if you blow within 10 minutes of drinking alcohol your reading will be higher than your actual B.A.C. from the alcohol in your mouth and throat evaporating.
So if you take a swig and blow right away you'll be off the chart!
I had zero luck finding info back when I acquired mine. I had hoped to set the threshold to the newer .08% limit.
These things were marketed like vending machines to guys with territories, you couldn't just go buy one back then, and when the outfit went under so did any hope of support.
OP, if you need the second pic in higher res, PM me your email. Pinside resizes...
LOL I just noticed the coin tray is a Rubbermaid desk drawer organizer module.
