(Topic ID: 226569)
Coin door switch plate missing
By ourdave76
11 months ago
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 11 months ago by LTG
#1 11 months ago
My South Park game worked fine until I was trouble shooting and ran a coil test, holding the coin door switches in for the test. Fixed the issue and upon trying to play we discovered the coin door was missing the bracket that holds the switches in. How did the game play for months without this part? How can I get it to play again?
#2 11 months ago
Was the knob on the high power interlock switch pulled out during that time ?
If it has a knob pull it out, if not, tape it closed.
#3 11 months ago
You got it LTG. We discovered 100 mentions in the manual about pulling it out to allow coil testing, and finally noticed one small mention that closing the coin door with the switch in the “out” position would reset it. I looked closely and still don’t see how it works, but it does. Does it just stay in the out position at all times?
#4 11 months ago
Quoted from Boise_D:
If you want high power yes. Your subject line indicates the switch isn't where it should normally be.
When installed correctly in the game. With the coin door open you can pull it out to turn on high power for testing coils and flashers. Or when you close the coin door, it pushes it in, doing the same thing, enabling high power.
#6 11 months ago
There are pictures in the manual and online, and they don’t show the bracket being there. The switch appears to be positioned like the pictures. I understand now how the switch works when it’s pulled out. But, I don’t see any physical contact when the door is closed. I suspect on this game the switch just stays out all the time, defeating its purpose.
#7 11 months ago
Maybe you have a different door on your game ? Flap missing, or bracket missing.
It isn't hard to imagine the door closing and the knob of the switch pushing in. Lift playfield up out of the way and look at closed door and see what has to happen to make the switch closed.
At one time, the switch wasn't left pulled out all the time.
Maybe post some pictures of what you have going on there for some ideas ?
San Diego, CA
Lorain, OH
5,999 (Firm)
Aurora, IL
Gweem's Mods
Spring , TX
Sparky Pinball
$ 74.00
Id Rather Play Pinball
$ 24.95
$ 2.50
Various Novelties
Pinball Wheezer
