Hey guys,do someone notice that there is mistake with dmd when you open coin door?When you open doir,dmd says"Coin door opened coils and flashers are disabled"but when i go to menu to solenoid and flasher test them works
It's a safety feature. All the high voltage stuff is disabled when the coin door is open in order to prevent accidental shocks.
Quoted from pekilica:Hey guys,do someone notice that there is mistake with dmd when you open coin door?When you open doir,dmd says"Coin door opened coils and flashers are disabled"but when i go to menu to solenoid and flasher test them works
Which game ? Some games have two switches. One kills high power when coin door opened, the other lets you know the coin door is open.
If you have the coin door open, a message that says coils and flashers disabled, but they work. You might be missing the switch, or it's broken.
Quoted from LTG:You might be missing the switch, or it's broken.
Or someone may have modified it intentionally.
On some Gottlieb games, I've seen the interlock switch moved and mounted on the inside and to the left of the coin door. Maybe someone did something similar here?
Quoted from LTG:Which game ? Some games have two switches. One kills high power when coin door opened, the other lets you know the coin door is open.
Attack from mars
Quoted from ForceFlow:Or someone may have modified it intentionally.
Maybe?
And what's the real playfield's high power?
This page was printed from https://pinside.com/pinball/forum/topic/coin-door-mistake and we tried optimising it for printing. Some page elements may have been deliberately hidden.
