(Topic ID: 306944)
Coin door alignment issue
By Vin-bot
4 months ago
  • 20 posts
  • 12 Pinsiders participating
  • Latest reply 4 months ago by Mr_Tantrum
    #1 4 months ago
    I have a alignment issue with my coin door that I can’t seem to fix..
    If I don’t screw the hinge to the bezel the door fits with clearance all around (except for the hinge side). When I screw the hinge in the door just touches the bezel and won’t close.
    I bended the edges of the door where possible.
    I loosened up the bezel, but adjusting that won’t make a difference (makes sense since it’s connected to the door hinge)
    Is there any obvious solution for this that I clearly missed?
    #2 4 months ago
    Pictures please
    #3 4 months ago
    Quoted from GPS:
    Pictures please
    0530575D-F887-4191-A2E7-A21562309B22 (resized).jpeg2C50F571-85C7-487E-BAEB-D61B86527659 (resized).jpeg55F8639D-C3E0-4D13-9FC5-518FC8CBE85D (resized).jpeg573B74BC-9B6B-4258-BD6F-6AA77E995DD1 (resized).jpegE18271FA-B621-47A0-ADFD-5D877D3CB764 (resized).jpeg
    #4 4 months ago
    You have a lip on on the coin door cutout. Try shimming the bottom of the pictured area out so that it sits flush with the rest of the coin door frame. A pic of where the door rests when when closed would be helpful. Basically your door is out of square and needs adjustment.
    #5 4 months ago
    Try putting some (blue) painters tape on the edge of the door and then close it. This will show where it hits and you can then bend it a bit.
    Blue painters tape is a bit better than normal white because you won't rip the paint off when you take it off.
    #6 4 months ago
    It’s touching on both the corners on the right hand side..
    Shimming the bottom left, will only make it worse..
    #7 4 months ago
    It's Hammer time
    #8 4 months ago
    That door face is bent an bowed. Looks like it’s been kicked an beat over its life. I would look for a new (used) door to replace it. I doubt you can bring it back to square…
    #9 4 months ago
    Just a thought here but if you loosen the bolts holding the frame in while keeping it in the cabinet will the door close? If so close the door and then tighten the bolts evenly and see if that does not help the issue. If not, as Pintopia has said it may be time for a new door. Hope this is helpful
    #10 4 months ago
    Easy fix with a hammer and a some patience. The front face was probably kicked in hard, causing the large "bow" you have. Just have to back it out in reverse. Work it on a large Anvil or find a good tinsmith.
    #11 4 months ago
    Oh that sucks bad..
    I tried finding a used or new coin door face, so far no luck.
    Anybody here that can help out or knows where to find them. It’s basically a Wico or Coinco face or a suitable alternative
    #12 4 months ago
    Check eBay these doors do come up an were also used on video games you should be able to come up with one with some persistence…
    #13 4 months ago
    #14 4 months ago
    Thanks, but really only after the “face/front plate”.. my back end is in good nick and I won’t like to replace the whole assembly.
    #15 4 months ago
    It’s basically a thin sheet metal pan not sure why it would be trash. Won’t ever be museum perfect but not impossible to fix. Put it on a flat surface and continue to bent it multiple directions till it lays flat. Seems more like your hinge is the issue by your photos.
    #16 4 months ago
    I got this coin door they are really good all around
    #17 4 months ago
    Problem solved !!
    I got some help from a mate that has experience in panel beating.. basically he manhandled it and “bashed” the door back into shape. To my surprise, the paint didn’t even get damaged.
    Big relief !
    #18 4 months ago
    Translation for those who don't speak Australian. In the United States the "panel beater" is known as the "body shop".
    #19 4 months ago
    Quoted from DumbAss:
    Thanks Mate..
    #20 4 months ago
    Quoted from Brtlkat:
    It's Hammer time
    …can’t touch this.
