Greetings!
Researching a project, and came across something that seems ambiguous (at least to me).
Coil voltages. What should be used? I see things all over the place with this ... seems like some machines were 24V and others were 50V ... but this is where it gets ambiguous (for me) the same kind of coils were used. Is that correct?
The 50V, apparently, gives more power which allows for a faster game, and steeper ramps. I understand that. But do these coils really support twice the voltage, which means twice the current, which means four times the power and not melt?
It gets stranger. In reading another thread here a little way down the forum asking about power supplies, someone said they bought an Antec supply from pinballcontrollers. I went to that website and they only have a single power supply ... and it's 70V! Now, that website is all about using P-ROC (which I'm not interested in) so I don't know if they're doing something with that voltage (stepping it down)?
What also peaked my interest is it was a 400W power supply which sounds very low to me considering, for example, an FL-11629 flipper coil is only 4 ohms. At 50V that's 625W and at 70V that goes up to 1225W!!! Now, I realize that's only for milliseconds until the EOS switch is hit, but on the flip side (ha!) the player can hit both flippers at once and on top of that it could be during multiball when other coils are firing. So.... something seems fishy to me?
Along those lines, are all the coils in a game run off the same voltage, or do some of the others run on lower voltages (like pop bumpers, pop targets, slingshots, etc)?
I was looking at getting a 50V transformer, which after being rectified would be ~47-48 volts. Close enough to 50. What I don't know is what VA rating I should go for. I was looking at a 1000VA which could easily do 20 amps. That's not quite the 25A both flippers would be simultaneously, but they do say at 60 Hz you can squeeze an extra 10% out of it just fine. 22 is pretty close to 25. However, that website selling a 400W (aka 400VA) one makes me wonder if I'd be going overboard. It's $50 vs $100 bucks, so twice the cost. Not exactly breaking the bank difference, but why waste money if it's not needed?
Sorry for the long-winded post, I'm just excited to plan out such a project
