I am working on a WWF that is having problems with the back panel diverter. The previous owner had accidentally shorted the two wires coming into the 32-1800 coil. This, of course, caused multiple problems upstream. Transistors and fuses were replaced, but still no luck with the diverter. I suspect the coil is toast, but I want to make sure.
I am getting voltage to only one lug, which I have read is a good sign the coil is bad. But, why does the coil ohm out correctly? I get 51 ohms (proper for this coil).
Is this contradictory?
-MK
