Hey guys,
I've got a coil stuck on my Jungle Lord and can't seem to get it fixed. It's the right drop target 3 bank reset coil and it locks on as soon as I power up the game. So far I've done the following:
-Replaced the coil and diode (I bought a 'working' board set so I thought it was on the playfield/wiring end at first)
-Replaced transistor Q23 with a TIP102
-Replaced predriver (q22?) twice, once with the original 2N4401 and once with a beefier 2N5550
-Traced continuity on the grey/green wire to the coil (it's good)
-Tested the 7408 IC2 (I did not remove it from the board, but it seemed to test good)
The coil is still stuck on. I'm convinced it's on the board as when I unplug 2P11 the coil does not lock on. Any thoughts on what to check next?
