(Topic ID: 204543)
Coil Stuck On - Baby Pac-Man
By pinmods
6 years ago
  • 11 posts
  • 4 Pinsiders participating
  • Latest reply 6 years ago by Biffbar
#1 6 years ago
Restoring my Baby Pac-man and ran into an issue when powering it up for the first time...
The center of the 3 coils on the 5 post drop target goes instantly to on right when I powered up.
I turned it off to prevent any damage and replaced the coil. Powered up again - same problem.
Thoughts?
#2 6 years ago
Bad transistor? Or did you check them already? In the past when I had a coil energize when I powered the game on it’s been a bad transistor
#3 6 years ago
Quoted from Bigbad:
I THINK I checked it correctly. Q33
Schematics here:
https://ia601409.us.archive.org/0/items/ArcadeGameManualBabypm/babypm.pdf
#6 6 years ago
.575 on one side
.667 on the other
#7 6 years ago
Quoted from pinmods:
Or just send you the board for you to bulletproof?
Might not be the board.
Pull the Coil fuse and then put the game in Switch Test.
Make sure there are no balls installed.
Are there switches stuck on? Do all the switches give back the correct switch number?
Is the new coil wired in reverse? Look at the band on the coil diode, as they can be soldered on either way.
#8 6 years ago
Quoted from vid1900:
No stuck switches. Coil diode on all coils(I have 3 spares from a parts machine) are facing the correct direction.
I changed all the connectors on the wiring harness and thought that maybe I had a wire in the wrong spot. Triple checked and they are all correct.
It's gotta be something on the board.
#9 6 years ago
Not sure if it helps but when I pulled off the J8 connector, the coil releases...
#10 6 years ago
Replaced the transistor. It lasted 3 power ups before blowing again. Thoughts?
#11 6 years ago
First thoughts: Could have been a bad transistor to begin with, then it became a coil diode issue (back EMF). The wiring to the coil terminals got mixed up, or the diode polarity was mixed up (coil was recently replaced).
Other thoughts: Perhaps too much current being drawn from a short in the wiring or in the coil winding. Is the correct solenoid circuit fuse in place (why wouldn't the fuse blow)? Was the game playing ok with the new transistor, up until it failed. Miss-marked or re-marked transistor, try another one. Something upstream of that transistor is locking it on.
$ 40.00
The Flipper Room
1,400 (OBO)
San Diego, CA
$ 45.95
$ 5.95
The Pinball Scientist
$ 9.95
This page was printed from https://pinside.com/pinball/forum/topic/coil-stuck-on-baby-pac-man and we tried optimising it for printing. Some page elements may have been deliberately hidden.
