(Topic ID: 122458)
Coil sleeves - can you buy long and trim down?
By EvanDickson
5 years ago
  • 5 posts
  • 5 Pinsiders participating
  • Latest reply 5 years ago by ForceFlow
    #1 5 years ago
    I want to try to tweak some of my flippers. A few are getting weak and dirty. I figure coil sleeves and flipper bushings are in order. Do I have to measure all the existing sleeves, or can I save time by buying the longest sleeves and trimming them down to size as needed?
    #2 5 years ago
    yes, you can trim them down...
    it is much easier just to get the correct sleeves...
    most of us have a small collection (ok, maybe not so small in some cases) of various sizes of sleeve... they aren't bad things to have around...
    #3 5 years ago
    If I need to trim one down to size I use an old plunger and insert it into the sleeve, cut to size with an exacto knife and file trimmed edged to smooth again.
    #4 5 years ago
    Quoted from EvanDickson:
    I do it all the time by inserting a wood dowl into the coil sleeve and then using a small pocket sized Pipe cutter that you can get at any home depot.
    One like this http://www.homedepot.com/p/HDX-Junior-Tube-Cutter-HDX003/204218579
    Makes perfect coil sleeve cuts every time.
    #5 5 years ago
    PBResource has a chart with part numbers, if that helps: http://www.pbresource.com/coilsleeve.html
    Quoted from Eddie:
    Clever approach!
    $ 89.99
    $ 10.95
    Tools
    Magaro Machines
    $ 159.00
    $ 189.99
    PinballBulbs
    $ 12.00
    $ 81.95
    $ 5,999.00
    Classic Game Rooms
    $ 55.00
    Pinball Photos LLC
    $ 159.99
    Medisinyl Mods
    Various Novelties
    Game Room Info Shop
    $ 85.00
    G-Money Mods
    $ 6,499.99
    Pinball Pro
    $ 144.00
    Lighting - Backbox
    The MOD Couple
    $ 66.95
    $ 26.95
    $ 1,000.00
    $ 27.99
    $ 209.99
    $ 4.99
    Playfield - Plastics
    $ 54.99
    $ 999.00
    $ 319.00
    $ 159.99
    € 6.50
    Buthamburg
    $ 19.99
    $ 9.99
    Filament Printing
    $ 6.00
