How much variance in coil ohm reading is acceptable? A spec of 32 ohm resistance is called for, but the replacement, same coil number reads 35 ohms.
Thats nearly 10 percent. This is Gottlieb EM hold relay. Should I just go with it?
On a hold relay of that much resistance, I don't see that it would make much difference. I'd use it.
A tolerance of 10% is pretty common in resistances. An actual resistor with no tolerance band would be 20%!
This page was printed from https://pinside.com/pinball/forum/topic/coil-ohm-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
