(Topic ID: 289505)
Coil issues - and dead flippers. Royal Rumble
By Gingerbloke
2 years ago
  • 2 posts
  • 2 Pinsiders participating
  • Latest reply 5 months ago by Ace85
    #1 2 years ago
    Hi Guys - so,I am having a battle royale with my Royal Rumble....
    I now have coil problems:
    Flippers don't work. When I press the button, they buzz - if I manually move them up they stay up - I believe the 8v is working but the 50v is doing nothing.
    The flipper board leds are not even flickering.
    Now in parallel, when I enter diagnostics - no flashers work. and when I test coils and flashers, some coils fire when flashers should fire - Mainly the corresponding L/R Coil fires when I select the flasher.
    Apart from the VUK that only fires when a flasher should fire...
    I changed the Q28,29,30 transistors and pre-transistors - no change
    I also own a maverick and I swapped the CPU & PPB board - no change.
    So I don't think this this is a problem with the boards or with the L/R coil
    anybody got any other ideas?
    Next step, I am going to replace all the coil diodes - could it be a bad coil?
    Thanks a lot in advance
    Mike
    2 years later
    #2 5 months ago
    Did you ever figure out whats wrong? I'm having same issues with my Tales from the Crypt. I swapped new power supply, ppb, and new rottendog flipper board and nothing. All flippers died mid game at the same time. Checked all fuses with meter and they're fine and so are the fuse clips. No burn wires. Check Cpu drivers with meter and they seemed fine as well. Bridge rectifiers also test out ok. No idea what to check next. Pops are dead and flippers are dead everything else works fine. My first pin so I'm still learning.
    This page was printed from https://pinside.com/pinball/forum/topic/coil-issues-and-dead-flippers-royal-rumble and we tried optimising it for printing. Some page elements may have been deliberately hidden.
