Hi flopflip
You should have "writed / written / wrote (?)": "Great, the pin starts-up, resets and gives the first ball".
Think of a fully running pin - what happens if you press the flipperfinger-Buttons after You have reached "Game Over" ? The answer is "Nothing" (A).
What happens if ... when the pin is resetting ... "Nothing" (B).
What happens when You bang a pendulum tilt ... "Nothing" (C).
(A) The Game-Over Relay has moved.
(B) The Reset-Relay is pulling.
(C) The Tilt-Relay is pulling (different ways in Gottlieb / Williams / Bally).
So the fault in Your pin is either a relay pulling when it should "no longer / not" be pulling (faulty-pulling) - OR the relay(s) do fine - BUT a switch-blade is bent causing "Switch is faulty-open".
Great, ipdb has a schema http://www.ipdb.org/machine.cgi?id=889 -> schema-F-3 shows the "Switch on Game-Over Relay" (relay in faulty position ? / Switch Blade bent - faulty-open ?).
Schema-F-4 shows the "Switch on Reset-Relay" (same questions).
Schema-F-10 shows the "Switch on Tilt-Relay" (same questions).
I suggest: Have a CLOSE / GOOD look at the switches - securely closing ? Contact points oxidate ? Wires soldered-on ?
I suggest (if the Fuse-problem is solved): Mark this topic as "solved" and start a new topic "Flip flop: Playfield not working" (in the new title: no Fuse is mentioned).
Greetings Rolf
