So, i have a coil that fires breifly but pretty hard upon power up. I think its the out hole kicker since i never see one fire and it sounds close to the front of the machine. Not that it matters, any coil fireing on start up is bad. Anyways, it only seems to do it when the game is powered down for a while. I tried leaving it off for 15-20 minutes and couldnt get it to do it, seems to do it when its off for the day and powered up the next day.
I replaced C30 i believe on the main board which solved the problem of the game not booting reliably (when this occured, you'd have to power it down then back up and it would boot fine.) i was hoping this would also solve the coil fireing on power up issue but it hasnt. It sounds to me like its a capacitor somewhere that is gone bad, possibly on the blanking circuit? Or rest? Im going to investigate all the components in the blanking circuit but can anyone point me in a direction or give me a heads up on the capacitor or the common one to fail?
Stange because if it boots fine, im assuming the blanking circut has done its job of locking out all the coils and giving the ok for the board to boot.
