Quoted from cmack750:Good to hear that I'm barking up the right tree...fingers crossed that does the trick. I'll update after I do it.
Well..... 48 days later, I finally got back around to looking into this further. Long story short, I believe I have found my culprit. Long version of the story, I'm not exactly sure...... Hoping for a little feedback. @vid1900 @MrBally
I pulled my cpu and driver board to take a better look at the 40 pin connector in prep to replace it. Much to my surprise, the 40 pin connector had very obviously (once I was able to look at the back of the board, anyway) been replaced sometime in the machine's past. To make matters worse, whoever did this wasn't exactly a soldering expert. Pretty ugly job.... But the joints appear to be sound nonetheless....
So, considering the soldering/desoldering that already took place and my lack of desire to potentially damage the board just attempting to clean it up or replace the connector again, I decided to check out the other basic culprits for the Solonoids (resistors, transistors, pre-drivers).
In doing this, with boards out of the machine, I ran a standard diode test against each Tip122 NPN Solonoid Transistor on the driver board. Everything looked fine and readings were roughly identical for each one. For grins, I set my multimeter to ohms and discovered that the readings for Q17 (front left 3 bank drop target reset) was approximately 10 times the reading of any of the other transistors.... And I was getting these readings regardless of whether I put the red or black lead on the base.....
Figured something didn't smell right there.
I checked Q17's resistors and pre-drivers and those readings looked in-line with all the other sets.... So I figure nothing is wrong with those.
Next, I pulled 2J9's cable (since Q17 pinned out to that) and powered up the machine. No blown fuse. Tested every Solonoid in diagnostic mode that wasn't running over 2J9 and no issues.
Next, I removed the Solonoid for the left front 3 bank target reset (associated with Q17) from the machine and just tied the 2 reds together to allow all the other Solonoids in the chain to still work. Reattached 2J9 and powered up. No blown fuse. Ran full Solonoid diagnostics and then played the machine for an hour straight. No problems at all... Minus the fact that my drop targets won't reset, obviously.
At this point, I'm comfortable saying I've found the Solonoid that was causing my fuse to blow. But does this sound like a transistor problem? If so, I guess I'll have to order a few Tip122 (or Tip102) NPN Darlington transistors, since I don't have any...... But the test I used to "find" the issue isn't normally what I've seen done to determine a failed transistor in the first place, which is what has be a little nervous that the transistor isn't an issue, since the "standard" tests in diode mode look fine....
Obviously, I'll check out the coil and its associated diode to make sure they are good, since if not, that would likely be the root cause (or that killed the transistor in the first place) , but was just hoping for feedback at to whether there is anything else I should check or if replacing the transistor is definitely in order here. Thoughts?
