I'm having trouble taming the ball-release coil in my TZ. It punts the ball clear over the diverter into the shooter lane.
I've tried not one but *two* replacement coils, each with a higher resistance than the last. The stock coil is a 26-1200, and I have now tried a 29-2000 and a 30-3000. The ball still sails over the diverter into the shooter lane.
Is it possible to "scrub" some power from the coil by limiting the length of the plunge mechanically? Let me explain. Picture a coil stop that is fully an inch longer than normal. That would stop the plunger sooner than normal, limiting its stroke and thus its power. Make sense? No, I'm not proposing making a custom stop; I'm simply proposing laying a cut segment of plunger inside the coil sleeve before inserting the plunger. With the segment sitting in the coil sleeve on top of the stop, the plunger's stroke will be limited by the length of the segment. Is this likely to work or not? I'm not keen on spending yet another $15 on another coil.
Thanks for reading this post and for any suggestions.
