I'm excited to update the code on my Deadpool Pro, but seem to be having some trouble. It's my first modern Stern game, so maybe someone can help me out and guide me through it?
My understanding is that I can download the new code from the Stern site, place it on a USB flash drive, plug it into one of the USB ports in the backbox, boot up the game and the code update will start automatically.
So I downloaded the new Deadpool Pro 1.08 code, and got those two files onto a flash drive. When I opened my backbox, I found that one of the USB plugs already had something in it:
I'm not sure if this is normal, but I took that out, plugged in my flash drive and powered on the game. Instead of updating the code, it just booted normally.
I figured maybe it needs to read the files from the original folder, so I re-loaded the flash drive with the code files inside the folder and tried again. Same result.
Any idea what the problem could be? Is there a setting that needs to be adjusted first? Maybe a problem with my flash drive? And what's that mysterious USB plug that I found?
Thanks in advance!
