I'm currently cutting my own custom playfield out of furniture grade plywood, and am now looking into coating it. I don't plan to paint it, just some kind of clear coat on top of the plain wood and light inserts. Also, I'm not the best painter, so considering that there's not going to be any paint, I mostly want something that is easy to apply well, and will dry/set/etc quickly, as I'm moving soon and would like to have the playfield assembled by then. (so talking less than an hour between coats, as few coats as possible, and the ability to bolt everything back onto the playfield in two days or less, even if it still needs to harden a bit after that before it's safe to play on). Also, do I need to coat the underside? (to help block moisture?)
