Quoted from jsa:Hmm. Just installed the LED and GI OCD in my BoP. Everything was LEDs when I installed it. Things were working great.
Yesterday I installed incandescents into the helmet. It worked great for about 24 hours. I noticed tonight the helmet lights not on. I tracked it to a blown fuse in F2. I replaced the fuse with the same (2A SB) and it blew almost immediately.
herg, do you recommend I replace the fuse in F2 with a 4A SB, or should I be looking elsewhere? Why would the first fuse last a day and the new one burn out after a few seconds?
GI OCD is really designed to be used with LEDs, not incandescents. You can use some incandescent, but if you have a string full of them, you will normally end up blowing the fuse, as you have seen.
BoP is a special case since the helmet lights are not directly controlled by the GI circuits. They get power from GI, but they have an extra level of control in between. Your best option, technically, is to move that one string back to the stock power driver board. This would require some custom cabling, though.
You can probably get away with increasing that fuse value as long as your total current draw (from all 5 strings) is not too high. The string drivers can handle much more than 2A, but the main power input is a bottleneck. There is a 2A fuse on each string, and 10A fuse on the main input. DO NOT increase the value of F1, the 10A one.
