(Topic ID: 99875)
Club LED OCD, tips, tricks, thoughts, and advice. (www.ledocd.com products)
By Matt_Rasmussen
5 years ago
  • 702 posts
  • 127 Pinsiders participating
  • Latest reply 19 days ago by Coyote
  • Topic is favorited by 119 Pinsiders
There have been 43 images uploaded to this topic. (View topic image gallery).
There are 702 posts in this topic. You are on page 13 of 15.
#601 1 year ago
Thanks. Set them all to 40. I couldn't really see any brightness difference between 35 and 40.
Couldn't explain how they all ended up on 100, but it's sorted now. Haven't been playing with Advanced at all, the default settings seem to be near perfect (great job herg)
Found out there is an unused string in TAF, so guessing that's 4.
Thanks for your help.
#602 1 year ago
Quoted from Rdoyle1978:
2) blinker bulbs don’t work real well with GIOCD, although on the site there is a specific FAQ dealing with this and a specific supplier named. You may ask Herg if you can just put incandescents (although don’t do it unless he confirms so you don’t blow the board!
You can, I do in my TZ. But you wanna keep the number of incandescents as low as possible, of course.
#603 1 year ago
Quoted from herg:
Blinker bulbs are hit and miss. I have a couple in my SS that work fine. Other in my TZ do not. I use incandescent blinkers in it because of this.
I believe is has to do with how the blinkers are implemented, and if they are without power for long enough they reset their sequence. That doesn't really explain why they wouldn't work at 100%, though. Is it a steady 100, or a ramp with a max of 100?
I have recently made an update to the firmware that increases the pulse rate to 1kHz. Believe it or not, I got a message from a guy that could see strobing at 250 Hz! Anyway, I'm theorizing this increased rate might also help blinker LEDs. I have some on order that I'm going to test. The only bayonet one I have works, but I want to fill all 6 spots in TZ.
This is from a long time ago but.. is there any benefit to setting the pulse rate to 1kHz? I think mine was on 500hz, which I presume is the default (also set to 50hz as I'm in the UK). I see "shimmering" in my GI and inserts if I try and set the brightness to much below 10. They are standard Comet 2SMD bulbs (not non-ghosting ones). If the pulse rate isn't likely to make any difference to that, I'll just leave it as it is and carry on leaving it starting on 10.
#604 1 year ago
Quoted from Durzel:
Some bulbs just don’t go down that low, but you should try the higher refresh rate, the shimmering may go away, that’s what that setting is for.
#605 1 year ago
Thanks.
I'm starting to wonder whether it's actually worth me routing two USB cables through the front of the machine (the two I received are not long enough to reach the coin door comfortably) given how much I'm already tweaking with it lol.
#606 1 year ago
rdoyle1978 has some really good answers here. Some bulbs don't like going to that low of a duty cycle. Trying the higher refresh rate and making your own determination is a good idea. It may actually make the shimmering worse, depending on the cause, though. If you're seeing bulbs that sometimes don't light at a narrow pulse width, setting it to 1kHz refresh will make that pulse even more narrow. If you're seeing strobing, setting it to a higher refresh rate should help.
#607 1 year ago
Quoted from Durzel:
Thanks.
That’s what I started doing - I don’t tweak them much any longer but it really helped. I think you might be able to use an unpowered USB hub and just connect the 1 cable
#608 1 year ago
Quoted from herg:
Hey I’m paying attention!
#609 1 year ago
I was a bit worried to use only cable tie for GI OCD mini PCB, so I've created a back panel, with cable tie connection, in order to isolate the back pins from Power Board.
herg, if you think this makes sense, I can send you the stl file.
20190224_190657 (resized).jpg20190224_190626 (resized).jpg20190224_191501 (resized).jpg
#610 1 year ago
How cool is that
Is there any reason B7 and B8 would be the same brightness in GI test (pin menu, not anything to do with GI OCD software)?
GI fades correctly from B1-6, but B7 always appears to be the same brightness as B8. I've even tried setting a big difference between B7 and B8 - e.g B7 is 10, B8 is 35 to no avail.
#611 1 year ago
Quoted from Durzel:
I can't say for certain why, but there is absolutely no difference in output between B7 and B8 from the games. As a result, I can't detect which one it's set to.
#612 1 year ago
Quoted from Davi:
herg, if you think this makes sense, I can send you the stl file.[quoted image][quoted image][quoted image]
Brilliant! I had the same concerns. I'd buy 6-8 of them if possible.
This Pinball hobby is causing me to consider a 3d printer purchase. Shapeways is convenient but quite expensive.
#613 1 year ago
Quoted from herg:
Ah well. I won't notice it really. Just glad my game isn't faulty! Thanks for the fast reply (again)
#614 1 year ago
Quoted from Reznnate:
Yes, it's possible. Any suggestion about fair price?
#615 1 year ago
Quoted from Davi:
davi, I thought this was a good idea, so I ran with it a bit. I thought, why not make it a bit taller, so it protects the sides as well. Plus, I made it print on it's end so I can fit more on the build plate at once. I'm going to start shipping these with GI OCD, at least for a while to see what people think.
#616 1 year ago
herg will there be any way for us folk in the UK to buy one? I'd definitely be keen to protect mine.
#617 1 year ago
Quoted from Durzel:
I'll post the stl file, but I won't be shipping them to the UK. Sorry.
#618 1 year ago
No probs, thanks anyway.
#619 1 year ago
Quoted from Durzel:
Herg, will you post them on your site for purchase?
#620 1 year ago
Hmmm... It would be pretty crappy of me to make you buy it when others will be getting them included. Maybe I'll put them up there free and you just pay shipping.
#621 1 year ago
Getting a bit ahead of myself here but how would this stay attached? Cable tie through the PCB holes as it is now? (guess you could use two instead of one looping over/under the edge connector - which isn't great) or nylon screws per your LED & GI board brackets?
Would it be feasible to have a small lip on the other side that would keep the PCB in place as it would only be held down on one side?
#622 1 year ago
It's a pretty tight fit as is, but the idea is that you'd still tie it down with a zip tie. In this case the tie goes through both the board and protector.
#623 1 year ago
Quoted from herg:
I wouldn't think of it that way. Lots of times products get things added to them at no additional cost. I was given some LED OCD's as a gift (that I have yet to install) and I wouldn't feel bad if you did this. Though I also don't have any desire to get one either. I'm sure I can figure out something out for mounting the board.
#624 1 year ago
I’d really like to do this. Would you guys be willing to send the .stl, or I’d even pay for the shipping. Not only does this protect from any potential shorts, but it has a great “finished” look which helps add to the already great product.
#625 1 year ago
Quoted from pinball_ric:
I wouldn't think of it that way. Lots of times products get things added to them at no additional cost. I was given some LED OCD's as a give (that I have yet to install) and I wouldn't feel bad if you did this. Though I also don't have any desire to get one either. I'm sure I can figure out something out for mounting the board.
Agreed. No sense selling something at a loss by only charging for shipping. Products evolve over time, and all of us buying them knew what we're getting (and not getting) when we buy them. I would definitely want one of these but I wouldn't expect to get one at lower than cost price a year after I bought GI OCD.
I'd rather you (like anyone) turn a profit if it makes this line of work sustainable for you. Taking a loss on each one shipped by only charging for shipping doesn't help that. Posting the STL online more than covers you for past customers I think.
#628 1 year ago
Quoted from herg:
davi, I thought this was a good idea, so I ran with it a bit. I thought, why not make it a bit taller, so it protects the sides as well. Plus, I made it print on it's end so I can fit more on the build plate at once. I'm going to start shipping these with GI OCD, at least for a while to see what people think.[quoted image]
Your solution is also nice.
#629 1 year ago
Hello. I just purchased my first LED-OCD board. I plan to install it in my LOTR today for the insert lighting. My insert lighting is roughly about 85% LED and 15% incandescent. Basically I have currently kept incandescent bulbs for the collection of all the fellowship characters, and the modes around the ring magnet at the top. All the other inserts are LED. From what I have been reading, I am getting the impression that I would blow the fuse because of the amount of incandescent lighting I still have in some of these inserts. Is that true? Also under my Mode Start insert I have a color changing LED. Will there be any issue with how the board handles that type of LED?
#630 1 year ago
Quoted from mordroc:
Herg should confim, but that sounds like a lot of incandescents to me. You may want to remove some and replace with LED then slowly re-add until you blow the fuse.
#631 1 year ago
That actually should be OK. Stern LED OCD can handle more incandescent than WPC because it has bigger transistors. When I owned LOTR, I did basically the same. All the characters and other clear inserts, I kept incandescent.
The color changer is a bit more difficult to predict. Some work, some get stuck on one color, and others don't light at all. My best suggestion there is to try it and see.
#632 1 year ago
Thank you. Appreciate the advice. That gives me the confidence to begin with what I currently have.
#633 1 year ago
In LOTR when you are in a mode and it says to shoot the flashing shots (Usually the Red Triangle inserts), the way they pulse/flash it's almost hard to tell they are flashing. I've watched some game videos and even with the incandescent bulbs it's not super obvious that they are "flashing."
Does anyone have any tips/settings for LED OCD to help see the flashing on the red triangle inserts better?
#634 1 year ago
Installation was very easy. Works great on the default settings. Color changing LED's still work too. Soon I will try and run the software just to see how it works for tweaking. A great product and it's amazing how it took my 8 year old LED's that have always flickered on and off in my LOTR, and instead made them fade in and out like normal incandescent bulbs.
3 weeks later
#635 1 year ago
I'm attempting to install my first LED OCD in TZ, but I am confused right off the bat on the instructions. Asking me to remove connectors from either J136 (only 3 pins) or J137 (8 pins) and connect the 4-pin ground connector there.
From looking around LED OCD will only work when GI dimming is enabled? Is this true?
#636 1 year ago
LED OCD has got nothing to do with GI so wouldn't be affected by that setting.
Not in front of my machine (TAF, but it's still WPC89) but the ground connection for LED OCD goes to the top right of the machine. It only goes there I think?
#637 1 year ago
you are correct... I was looking at the 95 instructions. Thanks, I will give it another try.
#638 1 year ago
Success, thank you Durzel for the fast response.
5 months later
#639 9 months ago
So I just got a STTNG and promptly installed the LEDOCD. I’m getting more
Ghosting than I’m used to - and this game appears to have just regular LEDs in it, not nonghosting ones.
I know if there’s a bad diode or other component it can throw off the LEDOCD board - but does anyone have a suggestion on where to start? The main one that is ghosting is the “battle simulation” insert, at the top of the mode wheel.
#640 9 months ago
Did you adjust the ramps at all? If you push the upper end of the ramp too high, you will get some flickering. (I get it in my TZ on a few inserts even on default values, so I'm sure part of it has something to do with the column/row transistors..)
#641 9 months ago
I'd start with single lamp test. Does the suspect lamp light when it shouldn't? If so, which selections cause it?
#642 9 months ago
Quoted from Coyote:
Pretty sure I left it on the defaults - but I installed it a week ago and haven’t lifted the playfield since, so I will have to check
3 weeks later
#643 9 months ago
Has anyone installed GIOCD and LEDOCD on a CV? Id like to install LEDs in mine but was getting some noticeable pulsing with both non -ghosting and regular comet LEDs. Not flickering completely off and on, but still annoying. It was happening in both the GI and controlled lamps
4 weeks later
#644 8 months ago
Where are non-US folk supposed to buy these from?
Comet sell the LED OCD, but to my knowledge have never sold the GI OCD.
Pinballshop.nl did sell both, for an exorbitant price (imo), but do not list the GI OCD at all anymore.
As far as I can tell there are no other suppliers.
Are non-US folk just screwed?
#645 8 months ago
I've already responded to durzel via PM, but will post this for others.
Comet actually does carry the GI OCD now. On https://www.cometpinball.com/products/led-ocd-boards, pull down the "Type" drop down.
#646 8 months ago
Apologies, I forgot I posted on here too. herg as ever was brilliant, responding immediately
#647 8 months ago
Quoted from herg:
Ace
1 month later
#648 6 months ago
Hi,
Can anyone tell me what type of #8-32 1/4" nylon screws are needed to attach LED and GI OCD to their respective brackets? (seen
here  and here)
You can't get these screws in the UK so I guess I'm going to have to try and import them from somewhere.
Looking at this website  for example, I can see choices for PAN (head I assume?), FLT (?) and "Binding", whatever that means.
Can anyone point me in the direction of the correct screws please.. herg ?
#649 6 months ago
Quoted from Durzel:
Hi,
hereand
here)
Looking at
this websitefor example, I can see choices for PAN (head I assume?), FLT (?) and "Binding", whatever that means.
https://www.mcmaster.com/94735a735-93135A351 Not sure if they ship international.
#650 6 months ago
Thanks. Will see if I can find some of those
$ 54.99
