Hello all, I just looked at a Close Encounters digital machine and found several problems are preventing game play. When powered up the machine goes through it's self test and displays "outhole switch stuck closed" although there is no ball in the outhole and the switch contgcts are open. This is a aftermarket mpu made in France, I can't remember the name of the manufacturer. Also, when put into the coil test mode the outhole coil is not energized although the other coils and sounds are tested properly. In addition when powered up the tilt relay is energized preventing the playfield illumination from working. The normally closed door slam switch and tilt ball roll over switch are closed and the normally open tilt pendulum switch and playfield slam switch are both open. If anyone has any ideas I would appreciate whatever help you may wish to offer. Thank you in advance.
