Thought I'd share a tip about the cliffy protector installation at the right scoop. There's a good bit of removal required, including a post bolt and nut that sits to the left side of the scoop and goes all the way through the playfield. You must also remove the scoop itself, pulling it down from underneath the playfield. However, one thing you do not have to remove is the subway that runs to the scoop from the hellevator, and I recommend not removing it because it can be hard to get back in--especially considering all the spacers involved. To avoid removing the subway, after removing the scoop, you can simply access the nut to the post that runs through the playfield from the side (see picture below). I'm very happy with the Cliffy--it's nice and flat and had no negative effect on gameplay, and I like how it's contoured to the scoop even to the point of beveled edges on the scoop interior. Great job Cliffy!
