Ok im installing my cliffys and I see they have a plastic cover on the top, this may be a stupid ? But do you leave it on or remove it ?thax
peel the plastic protective cover off. Then install the protector, then clean off your fingerprints..
Ok thax I figured but thought id double check. Now new issue dam post was thread locked in and it snapped which I suspected it probably would
Quoted from bigd1979:dam post was thread locked in and it snapped
I hate when that happens. Very common on system 11 games though. They used that blue loctite that grips like a mutha.
Just recently found out that if you put a soldering iron on the t-nut for a few seconds you can get the post out without breaking it. (I say this after snapping off just about every one in an Elvira)
Quoted from BadBrad97:Just recently found out that if you put a soldering iron on the t-nut for a few seconds you can get the post out without breaking it. (I say this after snapping off just about every one in an Elvira)
Now that's a good suggestion. Thank you.
This page was printed from https://pinside.com/pinball/forum/topic/cliffy-protectors-2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
