Hi. i just got a Cleopatra SS and i restore it. Now is finished but a have an issue. The flipper is weak and it cannot kick the ball to the upper rollovers. I have adjusted the flipper angle so that the flipper stays a little bit lower at rest position with better results, if you shoot at the edge of flipper, ball can go to the rollover, but i beleve that it is still weak. The same situation with the other flipper. My playfield angle is 5.5 degrees. Any suggestions please? Should i adjust more the flipper angle?
