Quoted from Mk1Mod0:Originally, there were non- magnetic brass balls installed.
To keep folks from using a large magnet to position the balls through the glass? Never thought about that! Or just to keep them from getting magnetized and changing the behavior of the balls? Both?
Yes, it prevents several problems - the most obvious being cheating - if you can drag and drop through the glass--- why not?
If the balls are magnetized, this becomes a problem as the neighbor ball will also become magnetized. When a ball passes by a magnetized ball held in a trap hole - *zing* - it sticks to the ball and will not roll down the playfield.
Bally added a device called a 'debuncher' into the trough to prevent magentized balls from sticking to each other during the lifting/startup sequence as this would be catastrophic. So even with all 8 balls magnetized, the games will all still play... just not very well.
