Quoted from barakandl:just clear all the audits with the coin door buttons. It can be done in 30 seconds. Get to the audits. Hit the cycle button, clear, cycle button clear, etc to the end.
There is no memory check for scrambled ram in these games like WMS did. If the CPU runs wild and drops a load on the RAM or the batteries die, you will end up with random junk in the RAM. Clear it manually and you are good to go. Most of the audits are worthless to a home use game. Just clear the first 6 or so, those are the high score ones typically.
Andrew
Andrew. I did clear all the audits, high scores etc, one by one as you described. I also replaced the fixit rom with a newer one since there is a lithium battery on the fixit rom. Still junk, but different junk!
In the mean time I had an mpu 200 laying around and didn't know if it worked. The SW came with an alltek mpu and the game ran fine. I needed it for another game which I sold together. I bought new eproms (2732) and jumpered the mpu for them. Also replaced the 5101's and the 6810 ram. There's no battery on this board. Amazingly the mpu booted and them game went to attract. Still getting the junk. The displays show numbers with spaces between them. 4 digits lit and 3 blank. I went into self test and the game shut down. restarted again ok.
So basically the same result with 3 mpu's. Problem must be the game. I'm thinking coin door. Everything else works, coils, sound feature lamps etc. Also no stuck switches.
