Replacing the ramps on the WCS I bought and giving it a good cleaning. There is ... something ... on the play field. Especially by the pops. Any idea what it is an best way to remove?
A179DAC7-8C9F-4666-AB77-2BB7033116A8 (resized).jpegQuoted from Mikala:Magic Eraser and 91% alcohol
That will strip the topcoat. I wouldn't resort to that right off the bat.
Quoted from arsmith7:There is ... something ... on the play field.
Is it gooey? Hard? Does it crumble? Does it flex or move at all? Can you pick at it?
It’s very hard.
I’ve tried naptha and it did nothing at all. Did novus 2 and it helped a bit. Used a plastic razor blade and chipped away at it a bit in some spots.
Quoted from arsmith7:Replacing the ramps on the WCS I bought and giving it a good cleaning. There is ... something ... on the play field. Especially by the pops. Any idea what it is an best way to remove?
You need to go with the most gentle thing that will clean it and progress only if needed. I cant tell what it is exactly, but here are my suggestions...and in this order.
Vacuum, use a dry soft cloth to wipe it, use a soft wooden tool (like a popsicle stick or an emory board) to remove hard crusting, novus 2, 91% alcohol, magic eraser.
oh, man. it’s simple. that’s schmutz! fingernail and some spit. stay persistent. this would have been my grandmother’s advice, and her house was usually tip-top!
My preferred cleaner is Gojo hand cleaner and a paper towel. Doesn't hut the top coat but make sure you wax after. Stuff works like magic. They sell it at autozone but make sure it is the "original formula" or you can get stuff that strips paint.
A little bit of this stuff on a paper towel is usually all you need.
Amazon has it too but in quantities that would last decades.
Quoted from ForceFlow:That will strip the topcoat. I wouldn't resort to that right off the bat.
Yes, you have that, but I was considering that it is located on a part of the playfield that does not get any ball action. No matter what method he uses, he will most likely still remove the topcoat. So clean it, wax it it and install the post back.
This page was printed from https://pinside.com/pinball/forum/topic/cleaning-whatever-this-is and we tried optimising it for printing. Some page elements may have been deliberately hidden.
