(Topic ID: 168836)
Cleaning post and other plastic parts
By Sonora70
7 years ago
  • 20 posts
  • 12 Pinsiders participating
  • Latest reply 7 years ago by eh97ac
    #1 7 years ago
    Trying to figure out a better way to clean the post and other plastic parts (obviously not "the plastics") when shopping out a pin. Anyone ever try tumbling them and if so what media do you use? Up till this point I have always wiped/scrubbed every single piece with a ME and alcohol. Fingers get pretty tired and it's just a tedious process. I thought of this last night while I was putting some of the metal pieces in my tumbler. Please share any other cleaning strategies that may be out there.....
    #2 7 years ago
    I thow em in the dishwasher and then use a tooth brush for more stubborn dirt.
    Sometimes the ultrasonic too
    --Jeff
    #3 7 years ago
    For plastic posts, toothbrush and simple green, then rinse with water.
    and, yes,
    Quoted from Sonora70:Fingers get pretty tired and it's just a tedious process.
    Have not found a better way yet, except maybe a ultra sonic wash???
    #4 7 years ago
    ultrasonic works great for plastic posts. Metal posts go in the tumbler with walnut media and novus 3 (whichever the heavy one is)
    #5 7 years ago
    I use an ultrasonic cleaner as well.
    #6 7 years ago
    Quoted from Cheddar:
    Quoted from ForceFlow:
    Yep.
    #7 7 years ago
    How long do you guys leave the posts in the ultra sonic cleaner?
    #8 7 years ago
    Couple of 5 minute cycles on hot for me
    -Jeff
    #9 7 years ago
    Ultrasonic cleaner....I've not seen one. I just googled and I'm finding them in the $30 range. Used for jewelry...is this what I'm looking for? What is the best size?
    #11 7 years ago
    I use a baby bottle top basket that goes in the dishwasher...the posts and lane guides and such fit in it fine, and then after the dishwasher a toothbrush and some soapy water gets the stubborn stuff. Set them upright on a towel to dry thoroughly and they are good to go.
    Phoebe
    #12 7 years ago
    I use a 2.5L cleaner. Sometimes it's a bit small, but it can fit most things.
    There are some that go up to 3.4 gallons, which would be good for large parts and wiring harnesses.
    #13 7 years ago
    I've had great luck with this unit: http://www.harborfreight.com/25-liter-ultrasonic-cleaner-95563.html
    Make sure to use a 25% coupon to get it for 60
    #14 7 years ago
    Thanks, I predict I will own one of these before the weekend is over.....
    #15 7 years ago
    Since we are on the topic of ultrasonic cleaners, any other uses other than cleaning plastic posts and small harnesses?
    #16 7 years ago
    I usually just throw them out if they're easy to find. New ones always look better
    #17 7 years ago
    Quoted from PopBumperPete:
    Basically any parts.
    For cleaning metal parts, I usually do an initial rinse, then put the parts in the ultrasonic cleaner, then derust in evaporust, then polish by hand or in a tumbler, then wax or seal.
    #18 7 years ago
    I had some nasty plastics that weren't
    responding well to the normal methods.
    Grunge off or other acrylic bong cleaner did the
    Trick!
    #19 7 years ago
    Update:
    I made the trip to HF and purchased the ultrasonic cleaner. I got the 2.5 liter version for $64 using a 20% off coupon (regular price $79.99). The first time I used it I was not impressed. I ran the same post through several cycles and still did not receive the results I wanted. After reading some other post about these cleaners I decided to increase the amount of Simple Green as I was only putting in a small amount. My new mixture is roughly 60/40 water to Simple Green. The results are fantastic! The additional cleaner made a HUGE difference. I can't believe I am just now picking up one of these cleaners. Well worth the $64. In fact, it saved me $25 just on this one pin as I was going to replace some of the parts until I saw how clean they could be, not to mention the ease and amount of time saved.
    #20 7 years ago
    Dial back the Simple Green and jack up the water temp. You should get the same results
    This page was printed from https://pinside.com/pinball/forum/topic/cleaning-post-and-other-plastic-parts and we tried optimising it for printing. Some page elements may have been deliberately hidden.
