(Topic ID: 161158)
Cleaning Playfield Harnesses - Vid's Guide
By vid1900
7 years ago
  • 128 posts
  • 52 Pinsiders participating
  • Latest reply 2 years ago by Vin-bot
  • Topic is favorited by 194 Pinsiders
    2 key posts have been marked in this topic
    Display key post list sorted by: Post date | Keypost summary | User name
    Post #5 What can vs. what should not go into the wash. Posted by vid1900 (7 years ago)
    Post #8 How to Operate the Wash Unit. Posted by vid1900 (7 years ago)
    Topic indices are generated from key posts and maintained by Pinside Editors. For more information, or to become an editor yourself read this post!
    There are 128 posts in this topic. You are on page 1 of 3.
    22
    #1 7 years ago
    By far the most dirty job when doing a playfield swap is cleaning the wiring harness.
    Anyone who has ever tried to take a shortcut and skips this step, quickly finds out what a mess black fingerprints make on every part of the playfield and rubber.
    The coil dust is carbon, iron and lead, so wear gloves.
    If you blow some of the loose dust off with an air compressor; do it outdoors and downwind from your garden.
    DO NOT blow that dust indoors and permanently contaminate your basement/garage.
    Be forewarned, people view their established cleaning routine with an almost religious fanaticism. Toes might get stepped on. Defense mechanisms will be on high alert and trenches will be dug in.
    It will all be OK, I promise.
    #2 7 years ago
    So we have a little prep to do before we do the actual cleaning.
    We of course, have to remove the wiring harness from the playfield.
    We want to remove bulbs and LEDs so the insides of the sockets can be cleaned.
    Label everything with 3M Blue Painters Tape, it will remain stuck on throughout the cleaning process.
    #3 7 years ago
    We want to remove Coil Sleeves, Yokes, and other disposable items that would be more trouble to clean than replace. The more soil load you put in the washer, the less detergent is available to clean the other items.
    A .40 cent coil sleeve is not worth your time to try to ream out (and you can never clean the metal flakes that are embedded into the nylon). You want to take the plungers out of all the coils, so they can be cleaned too.
    Really, just throw it away.
    #4 7 years ago
    If somebody sprayed WD-40 on the coils or something like that, then do a pre-clean with Naphtha so the detergent does not waste all it's power on the oil.
    Otherwise, this will be the last time you have to touch this mess.
    #5 7 years ago
    Coils, circuit boards and most everything else can get washed.
    Just don't put speakers, open relays, enclosed switches or other delicate items into the washer.
    Remember, Dish Detergent contains fine sand that scrubs off deposits. You don't want fine sand in your relays.....
    #6 7 years ago
    We want to put the entire harness on the top rack.
    The bottom rack is too close to the heating element, and if a Molex connector should fall through the rack and rest upon it, it will melt.
    Once the harness is arranged, make sure the scrubbing wand on the bottom of the rack is still free spinning. The washer won't clean well if the wand is obstructed.
    #7 7 years ago
    All the small brackets can go into the silverware basket on the bottom rack of the dishwasher.
    This is a good pre-tumbling step, as you never want to contaminate your tumbling media with dirty materials.
    #8 7 years ago
    In my experience, I know that most men have never learned how to run a dishwasher.
    Yes, they can somewhat put the dishes in the right spots and press start, but otherwise, they have no idea what they are doing.
    1. Call you wife and be SURE she is not coming home for at least 2 hours. You might not have been listening when she said that it was a 1/2 day at work for her.
    2. If you have liquid detergent, you have to shake it to disperse the sand in it that normally sinks to the bottom, before you use it.
    3. Liquid or powder detergent both work the same for cleaning harnesses.
    4. Run the hot water at the sink until it's HOT. If the dishwasher fills itself with lukewarm water, it will take forever for the dishwasher to bring it up to temperature. The wash cycle won't start until the water reaches 160*F.
    5. Fill both sides of the detergent cup for the Pots and Pan cycle. This cycle uses the most detergent of any of the presets.
    6. Close the door, press "Pots & Pans" and press (or turn the knob) to START.
    7. In about a hour the washer will play a little song that the "dishes" are clean and dry.
    8. The harness will be VERY hot and flexible, so put it onto a 24x48" sheet of cardboard to help you carry it.
    9. Check the trap at the bottom of the dishwasher for any small screws or staples that were hidden in the harness. If you leave them for your wife to find, she will know something is up.
    #9 7 years ago
    It was probably never this clean at the factory.
    The drops come out nice and clean (you know what a nightmare it is to clean them conventionally with a toothbrush).
    If you want to really get crazy, you can take the drops out, wax them and then reassemble.
    Clean, slippery drops never hang up, they drop like stones.
    Leaf switches come out looking like shiny copper from the sand blasting it gets from the detergent.
    #10 7 years ago
    So there you have it.
    In less than a hour you have a spotlessly clean harness that is a pleasure to work with.
    No caustic chemicals.
    No driveway rinsing.
    No hair dryer drying.
    No filling and soaking in the bathtub.
    No expensive equipment.
    No unsoldering coils or drop target mechs (how many hours would that add to your job?).
    Once you have done a dishwasher cleaning, you will never go back to any other way.
    #12 7 years ago
    Love!! i need that.
    #13 7 years ago
    Sweet guide! I've washed other parts in the dishwasher before and circuit boards in the bathtub lol but never thought it would be ok to put all you did in the dishwasher. The results look great! Those coils must have had a more plastic based wrapper though, I doubt a paper wrapped coil woild fare so well, or at least the wrap wouldn't.
    #14 7 years ago
    How did the decals fair on the other side of those drop targets?
    Funny guide by the way
    #15 7 years ago
    Quoted from merccat:
    Wrappers that are made of printed "masking tape" do totally fine.
    Homemade wrappers on regular paper end up in the strainer at the bottom of the washer.
    #16 7 years ago
    Quoted from Arcade:
    They were reproductions from ebay that came off in the wash.
    I've had OEM laminated ones that stayed on just fine.
    I just figure if I'm doing a playfield swap or restoration, I'm replacing the drop decals no matter what.
    Quoted from Arcade:
    Thanks.
    #17 7 years ago
    Oooooh this is just in time... I didn't have time to wash the harness from my Big Hurt rescue over the holiday, but I'll be trying it this week, maybe even tonight...!
    #18 7 years ago
    I've used a similar method and had great luck - but I always ran an empty load with more detergent once my stuff was all out of the washer to make absolutely certain I wasn't caught
    #19 7 years ago
    Quoted from johnwartjr:
    Can never be too careful ....
    #20 7 years ago
    my wife would more than kill me...
    #21 7 years ago
    Quoted from Syco54645:
    It's amazing that your wife can use your $300 chisels to open paint cans then shrug when you yell at her, but if you use the dishwasher you sleep in the doghouse.
    Move it on on over
    #22 7 years ago
    Quoted from vid1900:
    Will it Vid? Will it? LOL!
    I don't own a dishwasher due to our small kitchen size... NOW WHAT?!?!?!
    P.S. Great job on the guide!
    #23 7 years ago
    I use numbered stickers like below, I guess i should put these on something and run it through the dishwasher to see if theyre safe
    #24 7 years ago
    Quoted from MrBellMan:
    No, actually it wont.
    (and you are not getting the pony Santa promised you, either)
    You could buy a cool 22 liter ultrasonic cleaner for $299 on ebay.
    #25 7 years ago
    Quoted from iwantansi:
    If they don't stick, Sharpie will survive the cleaning and can be removed with alcohol.
    #26 7 years ago
    I actually bought the large vibrating tumbler from HF tools. I "think" the bowl can handle liquids.
    #27 7 years ago
    Blech, I'd never put these where my plates go. (Especially the nasty EM cloth ones)
    Community washing machine? Much better...
    59681aeed7959fe47c552c8695b38a6090313333_(resized).jpg59681aeed7959fe47c552c8695b38a6090313333_(resized).jpgac543c3748034c253c9c1a14139d0b5c45f643a3_(resized).jpgac543c3748034c253c9c1a14139d0b5c45f643a3_(resized).jpg5ca970eb7527eb988494a5b214c6e92a708f51d8_(resized).jpg5ca970eb7527eb988494a5b214c6e92a708f51d8_(resized).jpg400556164a8b5fde57d8ed56d30ab207e937be7a_(resized).jpg400556164a8b5fde57d8ed56d30ab207e937be7a_(resized).jpg
    #28 7 years ago
    Are you just soaking or running the machine? I would be afraid the wires would get caught up in the motor or something...
    #29 7 years ago
    When the dog pukes in his bed, I always take it to the laundromat so I don't contaminate my home machine.
    #30 7 years ago
    I ran it on delicate for the 30 minute time slot it gave me, through two spin cycles + a rinse and even took all the plastic pieces off (those are not zip ties/plastic btw, they stayed of course) and threw it in the dryer since most of it was cloth (EM harness), but to save the insulated wires for the 120v I didn't leave it in very long
    It was pretty compact though, I don't think I'd put ones in there where every wire is super stringy. Definitely took a leap of faith but it turned out fine. It did lose a bit of it's shape though, which is slightly annoying putting it back together (saving a parted out machine, everything was cut from the harness) even if you have a schematic, it would have been nice only to use the schematic to "double check".
    #31 7 years ago
    Welp, I always knew this day would come...
    Friggin' Gottlieb and their tank-like build quality... when I removed the harness I simply unscrewed the mounting brackets from the PF, but damn... on Big Hurt at least, those brackets must weigh over 10 pounds combined! Took me another hour to remove them all and label the coils.
    Actually the coils are probably the least of my worries because if the labels on all the Molex disconnects come off, I'm well and truly screwed!
    But, since I had to remove all the brackets and mount plates anyway, may as well throw 'em in and see what happens.
    I do have one advantage though:
    Zee wife, zometimes zhe iz pretty kewl. Like tonight. See those dishes in the sink, they were in the washer pending a cycle... I took 'em out and piled 'em there. They can be bathed AFTER my harness is done. Our next meals might be pinball-seasoned! Mwuahaha.
    #32 7 years ago
    Excellent write up as usual Vid. Can Gottlieb switch stacks eg Ax, Bx and player control motor be put in as well?
    #33 7 years ago
    You're not alone
    #34 7 years ago
    Move it on on over
    Well technically I purchased the dishwasher and installed it. It was a very expensive piece of equipment ($1200 at the time) so I am not sure I would want to get all of the crud into it. Since the dust may contain lead couldn't that be bad for your dishes afterwards? I mean it cant all get flushed out.
    #35 7 years ago
    Your dishes don't care about lead poisoning, the people eating off those plates might be a different story. This is the only reason I have never done the dishwasher method. I am generally not a "nervous Nelly" but putting lead, lead/dust into a device that will clean items I and my kids will eat off of? No thanks. I would be willing to bet you can not find one poison control expert that would endorse this practice. Do I really think there is a danger? Probably not. However, I doubt you can find any research that shows that it is safe because lets face it, the general population would not consider putting lead into a dishwasher
    #36 7 years ago
    I've used the lead tester at work and it does not detect lead on a swipe from the walls of my dishwasher after washing a load of circuit boards. I assume circuit boards have 100x the lead of a wiring harness.
    Dishwasher detergent has sheening chemicals that keep minerals from sticking to the sides of dishes and glassware - that's why you don't get spots all over your glasses.
    Your favorite coffee mug from China probably has lead in the glaze that leaches out every time you pour hot liquid into it.
    #37 7 years ago
    Entire circuit boards with chips, etc. go in too? Anything special to make sure everything's dry before power up?
    Heated dry in the dishwasher?
    -1
    #38 7 years ago
    Would have thought you would have mentioned that earlier on in the post, if you were somewhat concerned (or even remotely questioned) about the possible lead contamination that you tested your dishwasher. I'm sure you thought others may have had the same thought? Glad your swipes came up clean, but I still doubt you will find someone in the poison control industry who would be OK with putting lead (not contained in a glaze) in a dishwasher. Not trying to sink your process here, just think people should know of the potential risk that they might not have thought about.
    #39 7 years ago
    Quoted from Mamushka:
    It was more of a circuit board thing than a wiring harness thing, as all the solder on those old boards is lead.
    We do lead testing at work, so it's always interesting to me.
    I agree with you 100%.
    Everyone should think about this (if they haven't already):
    Aluminum cookware is banned in many parts of Europe and SA.
    Stainless Steel cookware can leach toxic chromium and nickel into your foods. Hell, even the inside of your dishwasher is low grade stainless.
    Your expensive copper bottomed tea kettle leaches heavy metal into your tea.
    If your Teflon pans were made before 2015, they leach PFOA into your food.
    If you feel any worry about using your dishwasher to clean circuit boards or wiring harnesses, get a $299 Ultrasonic and it's basically the same process.
    If you don't think your dishwasher is rinsing properly, you can also test your own dishwasher for any residual lead dust with a $10 test kit:
    #40 7 years ago
    We have a survivor!
    Thank Zeus, the paper Molex disconnect labels (Gottlieb probably put 40 of them on here) survived! Looks like the few casualties were the labels on the flipper coils - which were probably replacements and so used cheap paper instead of "masking wrapper" - and a couple other random coils. Most survived just fine. There's no trace of the coil paper in the washer (gone just like the paper labels on pickle jars and beer bottles ha ha). Only straggler parts in the bottom were a couple loom clips that slipped off.
    But being the idiot I am, I forgot to ID tag the coil wires with blue tape. This is because I originally tagged the mounts / mechs / plates with Sharpie... only when I realized they were just collectively too damn heavy and bulky to fit in that top rack, the subsequent hour+ of removing them all pressured me for time and distracted me from remembering the tape. Instead I'd marked the coil ends with Sharpie, but that washed clean off the nylon!
    Ironically though, the Sharpie did stay on the metal parts (as I originally intended), so hopefully I can puzzle this out with the manual.
    If this were a WMS game no big deal since apparently WMS only knew like 5 coil specs ha ha... but I swear there's at least 20 coils on this GTB Big Hurt harness and not a damn more than two or three are alike
    Anyway, at first glance I can say it was worth it: no more grimy coatings, no crusty dirt; the few leaf-style contacts look cleaner and the bulb sockets are especially brighter. I washed the coil sleeves in the utensil basket for the hell of it and they are much improved as well - not perfect owing to poor spacing, but I can manually clean them easily. They were in good shape so now I don't have to spend an hour comparing sizes and flanges and part numbers for a dozen different sleeves.
    There's some trace crud in the washer but nothing a quick rinse cycle with a vinegar bath wouldn't handle.
    10/10 would do again if I have to. Thanks Vid!
    #41 7 years ago
    Quoted from goingincirclez:
    I dont see the need to label anything.. just take sufficient amount of before pictures and you will have no problem putting it back together. The wires have "memory" in that they will lay out out how they have laid out (more or less) for many years. In my restorations worst issue usually is an inlane switch or lamp reversed. Just test the game before installing all the topside parts and you can quickly confirm everything is back where it should be.
    Thanks Vid for the guide. Usually I soak the harness in a large rubbermaid box cover and soak it in Bleache Wite equivalent like purple power or simple green but this is just to easy not to try. Funhouse harnesses going in the dishwasher soon!
    #42 7 years ago
    I absolutely love the way the things look coming out of the dish washer, but I just can't bring myself to do it either. Just doesn't sit well with me. Great thread though as usual. Guess I'll have to spring the $299 for the big ultrasonic cleaner!
    #43 7 years ago
    Dear Vid,
    My first time trying this tip, I used powdered detergent. Overall the result was good, but I had some soap residue stuck in some tough to clean places. My plan is to try liquid or use less powdered detergent next time. Any suggestions to make sure ALL the soap is rinsed away? (I did not use the pots and pans cycle)
    -mof
    #44 7 years ago
    Quoted from mof:
    -mof
    Use the correct amount of soap for the cycle you select. Too much soap won't dissolve, too cold of water won't dissolve.
    You can put the harness back in without soap and run Pots&Pans. The hot water will dissolve your remaining soap.
    #45 7 years ago
    I'll do that from now on as step 2 for good measure.
    -mof
    #46 7 years ago
    Thinking about trying this with my Nine Ball restore (https://pinside.com/pinball/forum/topic/1980-stern-nine-ball-restore-seshpilot). More than anything though, I'm grateful for a Vid-approved guide on how to actually wash dishes correctly in the dishwasher! Thanks again Vid.
    #47 7 years ago
    Quoted from seshpilot:
    You can't trust guys with a dishwasher.
    They hook up the water line to the cold water pipe.
    They put too much soap in so it can't dissolve.
    They put the 24K gold trimmed fancy plates in it, so the sand can sandblast all the gold off.
    They put all the spoons in one compartment, so they "spoon" together and don't get cleaned.
    They use regular Dawn dish soap, so everything is covered in streaks and spots.
    #48 7 years ago
    Quoted from Topcard:
    OR get a second dishwasher for less money..
    #49 7 years ago
    Quoted from JoeJet:
    No joke.
    You could run a garden hose from the laundry tub to a dishwasher for hot water.
    $113 and you are good to go:
    http://www.searsoutlet.com/14012-24-Built-In-Dishwasher-White/d/product_details.jsp%3Fmd%3Dct_md%26cid%3D224%26pn%3D1%26ps%3D25%26pid%3D90645&mode=buyUsedOnly&itemSelectionType=all
    .....and just think. If you have an electric stove you garbage picked for your powdercoating, you garage only needs a fridge and it will have a complete kitchen.
    #50 7 years ago
    Amazing Vid!
    I'm starting a total restoration soon and your threads are invaluable - playfield thread was great but this one is even better it's the one area I was a little concerned about but I'll be following yours posts in this thread step by step, thanks man appreciate sharing your knowledge in such a detailed way to help people like me doing a first time full restore
    This page was printed from https://pinside.com/pinball/forum/topic/cleaning-playfield-harnesses-vids-guide and we tried optimising it for printing. Some page elements may have been deliberately hidden.
