(Topic ID: 205052)
Cleaning Playfield
By HD_Fatboy
6 years ago
  • 20 posts
  • 9 Pinsiders participating
  • Latest reply 6 years ago by jrpinball
#1 6 years ago
Hi All,
I have been reading about playfield cleaning, and there of course many opinions
My Gottlieb High Hand I cleaned with Novus 1 and Novus 2 It did a good job.
I tried some Novus on this GP playfield and its not touching the black. I do not know what's on here for coating so I just don't want to try anything.
Thanks in advance!!!!
#2 6 years ago
Quoted from HD_Fatboy:
Use the search function for magic eraser, and read up if it will help you.
#3 6 years ago
Thanks for your reply
I read about it, do you think it will work with no ill effects?
#4 6 years ago
I would personally only use magic erasers if I was planning on clear coating it after.
#5 6 years ago
I never did a clear coat job. I was hoping to just wax.
#6 6 years ago
Wax after magic eraser with alcohol will be ok. Just don't over do it with the magic eraser or you will remove paint. To clean the magic eraser residue, I use naphtha on a rag and then wax.
There are other methods and opinions on this subject.. Magic eraser can be your best friend or worst enemy if you scrub too hard.
#7 6 years ago
Quoted from bonzo71:
Wax after magic eraser with alcohol will be ok. Just don't over do it with the magic eraser or you will remove paint. To clean the magic eraser residue, I use naptha on a rag and then wax.
Thanks I will try it
#8 6 years ago
To clarify, is use naphtha to remove the magic eraser residue. I didn't get time to edit prior to your reply.
#10 6 years ago
Here is the lower playfield after using Naphtha and a magic eraser, looks like black is there forever.
#11 6 years ago
Yeah, it's tough to see. ( maybe add the picture )
#12 6 years ago
Use alcohol on the magic eraser and naphtha to wipe of any residue left by the alcohol/magic eraser. The black will come off
#13 6 years ago
Apply light to medium pressure with the Magic Eraser, your not scouring 25 years of rust off of a chrome pinball leg. Be careful around the inserts, that black ink on any raised parts will disappear in a jiffy.
#14 6 years ago
Sorry I forgot
the picture
#15 6 years ago
Here is a picture with alcohol on a magic eraser followed up with naphtha. scrubbed a little bit harder but black still not coming off....sigh
#16 6 years ago
I think the Novus you used over that black schmutz kind of sealed it into the paint, making it very difficult to remove. Getting black off of yellow on a playfield is very tough to begin with. Bad move using Novus before cleaning first. I'd keep cleaning with 92% alcohol and a somewhat abrasive rag or gauze pads until you start getting a dullness to the paint, then carefully use ME and alcohol. Proceed with caution though.
#17 6 years ago
Quoted from jrpinball:
Thanks JP, I appreciate it!
#18 6 years ago
So THATS why I have such a hard time removing ball swirls. On a new game I usually hit it with novus before the eraser and then wonder why the ball swirls take hours to get out at times.
#19 6 years ago
Quoted from KingofKoopas:
Basically he's talking about rubbing the dirt in deeper. Swirls/etc are dirt sitting in the cracks in the finish. Anything that helps clog that up or pushes it deeper.. makes it more difficult.
As long as the novus residual is removed its more about the consequence of working it in deeper...
#20 6 years ago
Novus contains DE; that is diatomaceous earth. It's an extremely fine abrasive, and polishing a dirty playfield with it will mingle the dirt with the paint on a microscopic level. Once you've done this, it's nearly impossible to separate the dirt particles from the paint, unless you carefully work your way down to a level of paint that is dirt free.
The Pinball Scientist
1,000
Burlington, VT
1,650 (OBO)
Lincoln Park, NJ
$ 24.98
Hardware
Gameroom Mods
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/cleaning-playfield-3 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
