I agree with the dishwasher. I owned a business that has repaired thousands of PC boards from electric lift trucks over the years and the dishwasher was my best tool. I used to use a "vapor degreaser" machine that utilized Freon as a cleaning media, but since has been outlawed.
Dishwasher works well, but I would remove the IC's first, clean under them, then install a socket. Many times, corrosion forms under the IC and you'll only trap it if it's not cleaned properly. Plus, it gives you a chance to inspect copper traces that may have been acid damaged and hidden under the chip.
Also a real good tool is one of those electric "Dental Water Pic" machines that induces a high pressure water jet that can safely remove dirt and corrosion, and clean out connector terminals easily.
Set your oven to warm, to hasten evaporation of collected water. It only takes a few minutes to dry. Or use a heat gun on low.
