A quick (and easy, I hope) question. What do people clean the inside of the cabinets with? Boards, wiring and wood. I wouln't like a lot of water/soap in there due to wood swelling and effects on electronics.
Basic: vacuum while using a soft 2" paintbrush to loosen dirt.
A bit more: remove everything, cover with Scrubbling Bubbles, wipe off. Lifts dirt like no other and kills bad odors.
Scrubbing Bubbles also works great on circuit boards. Spray, let sit, rinse in running water, let stand for a few minutes, blow off with compressed air, then let sit in front of a fan for a hour or two. Use with caution naturally, but I've had 100% success and the boards look beautiful.
Thanks for that. I don't think Australia has this beast yet. Is it just foamy soap?
I'll try the paint brush and vaccuum trick first.
Quoted from dendoc:Thanks for that. I don't think Australia has this beast yet. Is it just foamy soap?
Oops ... My "tiny flag recognition skills" were tested and I failed. Okay, Australia and not GB, got it! Now edited.
Anyhow, yeah, I guess it's just foaming soap, but check the Material Safety Data Sheet on it for contents. Maybe from that you can find a similar product.
Quoted from cal50:A palm sander and some 100 grit makes it look new........
Even 80 grit if it's real dirty
This page was printed from https://pinside.com/pinball/forum/topic/cleaning-inside-the-cabinet and we tried optimising it for printing. Some page elements may have been deliberately hidden.
