What's your process?
I plan to relabel them, so peeling the old label off is not a problem.
I also have an ultrasonic cleaner that I could use, but I'm afraid of cleaning off the enamel coating on the wire and ruining the coils.
Purple Power and a small brush. Tooth brush works great.
Good rinse.
Then use compressed air to blow them dry. Takes quite a bit of air to really dry them, since water gets in behind all the windings.
I’ve gotten good result using ultrasonic and simple green. No issues so far, but I’m curious if any one has had problems losing enamel off windings and causing shorts.
Do the coil windings themselves really get that dirty? I know the paper wrapper can get dirty, but not really the windings themselves.
Ultrasonic cleaner does not harm winding or enamel.
I don't usually clean pinball coils in US cleaner, but I have done many DC motor armatures from jukeboxes etc, that are full of carbon dust from the brushes mixing with gummed 50 year old lubricants.
Quoted from Tuukka:Ultrasonic cleaner does not harm winding or enamel.
Depends on chemicals you use in the cleaner.
I used it for stripping paint off of brass model steam engines. 1/2 water 1/2 ammonia worked great at paint removal.
Yes of course. But the US itself is safe. I use a drop or two of ordinary dishwasher fluid.
-Thanks for the tip on paint removal!
This page was printed from https://pinside.com/pinball/forum/topic/cleaning-coils and we tried optimising it for printing. Some page elements may have been deliberately hidden.
