(Topic ID: 227264)
Cleaning black rubber residue from playfield and everything
By Jptrains
5 years ago
  • 17 posts
  • 9 Pinsiders participating
  • Latest reply 5 years ago by Jptrains
    #1 5 years ago
    Hi I just started on a new project. Sega Harley Davidson.
    The playfield and everything has black rubber stuck onto everything and ground into the Playfield. Almost to the point of completely obscuring the graphics in places.
    So far, I have been using rubbing alcohol with a paper towel and elbow grease. It has been working but it is slow going and tedious.
    Is there a better or easier way to remove all of this gunk?
    Thank You in advance.
    #2 5 years ago
    Sounds more like coil dust that has built up. Novus 2 should get through it if it is.
    #3 5 years ago
    You could also try CP100.
    #4 5 years ago
    And dont use paper towel. Use microfiber cloths. You can find them cheap
    Also you dont want rubbing alcohol its watered down.
    Use 99% isopropyl alcohol or novus 2 or naptha
    #5 5 years ago
    CP100 will take the residue off of everything. It's especially effective at cleaning rubber rings. Novus 2 is my preference for the playfield and plastics, though. Use sparingly and buff to a shine with a cloth. Once clean, I typically throw down a coat of carnuba paste wax (Mother's) for protection.
    #6 5 years ago
    Awesome thank you for the advice. I’ll be getting some cp100 99% alcohol and microfiber wipes.
    I have the carnuba paste wax for a good wax and buff after cleaning.
    #7 5 years ago
    You don't need to use the alcohol if your going with CP100
    #8 5 years ago
    For how bad it is, I would prefer to use a cheaper fluid to remove the bulk of the gunk.
    The crud is very thick to the point of almost blacking out the playfield graphics, white and yellow are practically black where I haven’t cleaned.
    And it’s rubber too, the stuff is chunky, in addition to tons of the fine coil powder. The rubbers are badly cracked and disintegrating. Vegas heat does a number on rubber.
    #9 5 years ago
    Quoted from mollyspub:
    CP100 is 99% Naphtha and 0.6% paint stripper.
    A gallon of Naphtha is only $14, so you can probably save a lot of cash and just refill your CP100 bottle with Naphtha.
    https://pinside.com/pinball/forum/topic/cleaning-and-waxing-pinball-machines-vids-guide
    d8198f5cde624bc298b7f24e78e217f9aa5c13a8 (resized).jpgd8198f5cde624bc298b7f24e78e217f9aa5c13a8 (resized).jpg
    #10 5 years ago
    Holy crap. Pictures?
    #11 5 years ago
    Okay, unless the previous owner was using black rubber balls at 200 degrees instead of pinballs, I doubt it is "black rubber residue."
    I'd love to have seen pics.
    #12 5 years ago
    I’ll see if I can post a pic or two of what’s left that I haven’t gotten to yet
    #13 5 years ago
    I bleach the black rubber off of plastic parts, but it will rapidly increase the rate of oxidation on metal parts.
    20181015_200204 (resized).jpg20181015_200204 (resized).jpg20181015_200710 (resized).jpg20181015_200710 (resized).jpg20181016_061446 (resized).jpg20181016_061446 (resized).jpg
    #14 5 years ago
    The photos don’t do it justice. It shows the chunks. The coil dust shown is not the worst spot I’ve cleaned the worst already before posting.
    1E5EFB03-2FBD-4EF2-B2F1-3398A1E7F9DE (resized).jpeg1E5EFB03-2FBD-4EF2-B2F1-3398A1E7F9DE (resized).jpeg43D0DBA4-D2D6-4754-A235-FE5489F08033 (resized).jpeg43D0DBA4-D2D6-4754-A235-FE5489F08033 (resized).jpeg76358AAD-117D-461B-92D7-9CC55B5D3E42 (resized).jpeg76358AAD-117D-461B-92D7-9CC55B5D3E42 (resized).jpeg
    #15 5 years ago
    That's not too bad. Even just Novus 2 should take that off with a little buffing. I would avoid using rubbing alcohol until trying that, or CP100 first.
    #16 5 years ago
    Quoted from Tomass:
    Ops used double sided tape to hold the rubber on the flipper, you can see the outline on your parts before bleaching.
    #17 5 years ago
    Thank you for the Naptha tip. It works like a charm.
    This page was printed from https://pinside.com/pinball/forum/topic/cleaning-black-rubber-residue-from-playfield-and-everything and we tried optimising it for printing. Some page elements may have been deliberately hidden.
