(Topic ID: 137689)
Cleaning and Waxing Pinball Machines - Vid's Guide
By vid1900
8 years ago
  • 2,210 posts
  • 439 Pinsiders participating
  • Latest reply 9 days ago by Jagrmaister
  • Topic is favorited by 1,181 Pinsiders
    5 key posts have been marked in this topic (Show topic index)
    There are 2,210 posts in this topic. You are on page 40 of 45.
    #1951 2 years ago
    So I played R&M this weekend on a pin I don't normally play and was scoring in the millions, whereas normally I'm not even close. I could see the ball wasn't sliding or moving normally. Later I saw them cleaning the playfield and asked what they were using. She said Naptha to clean lol. I said that's not a good idea, but she wasn't having it. Moral of story? Strip all wax off and get new high scores!
    #1952 2 years ago
    Quoted from Bamaro:
    Not to get too technical and at the risk of restating points made earlier, 100% carnauba is very hard and could never be applied to a pinball machine. Commercial products are softened by the addition of solvents, petroleum distillates and oils.
    Yet when the solvent evaporates if its 100% carnauba it will be rock hard.
    The key is 100% carnauba.
    3 months later
    #1953 2 years ago
    In regards to the Blitz wax being hard to remove the lid after it has been opened, how about cutting a small square of saran wrap and put over the top of the container before screwing on the lid ? Wouldn't that keep the wax from getting hard under the lid and keep it from being hard to open ? Just a thought .
    #1954 2 years ago
    Quoted from bjab:
    It's not actually hard to open.
    You press the lid down, as you turn it CCW and it easily unscrews.
    Let all your friends try to open it ( "hey, you're a strong guy, open this for me..."), then when they can't, put your left hand on the bottom, your right hand on the top, push together and unscrew. Fun laughs for all involved.
    #1955 2 years ago
    Quoted from vid1900:
    Since you are around and giving excellent advice. Does Blitz go bad if the lid is secure. A couple of years? I ask because I did probably the most thorough cleaning if my Met to date. Blitz was somewhat shrunk, but once It warmed up a bit, it seemed ok to use. Don't want to make the same mistake 2x. Is it just better to replace every couple of years. One pin, soon to be two. Thanks for all the advice!
    #1956 2 years ago
    Quoted from Roostking:
    Since you are around and giving excellent advice. Does Blitz go bad if the lid is secure. A couple of years? I ask because I did probably the most thorough cleaning if my Met to date. Blitz was somewhat shrunk, but once It warmed up a butt seemed ok to use. Don't want to make the same mistake 2x. Is it just better to replace every couple of years. One pin, soon to be two. Thanks for all the advice!
    Actually, while your here. Any new products too check out since you started this thread?
    #1957 2 years ago
    While you are here, any new products to check out?
    #1958 2 years ago
    I found a decade old jar that I must have been using on my motorcars, inside a stack of buckets. The wax shrank a little, but it still was fine.
    I've tried a few new products that companies have sent me, but Blitz still lasts the longest.
    #1959 2 years ago
    I bought one jar in 2015. I think it was the last one after they had a fire that destroyed some inventory. I don't know, but it taught me to be more efficient with it, which is probably good for my playfields anyway.
    I will admit though opening the jar has been a struggle. Now I will hold my head down in shame after learning the trick.
    #1960 2 years ago
    Awesome topic, so glad to find such a deep discussion here as a newbie to pinball.
    Random question after reading this as someone who has detailed cars a bit. Does anyone ever use a clay bar on a playfield? I am always amazed at what a clay bar picks up from a seemingly clean car.
    Also, I tend to get a lot of white haze and clumps of wax after a few games using Blitz wax. Does that mean I'm probably using too much?
    P.s- glad I'm not the only one struggling with the damn Blitz wax container lid! I make sure to spin it counter clockwise so the threads line up perfectly before tightening. If you cross thread it good luck.
    #1961 2 years ago
    Quoted from Anony:
    You are using WAY too much wax. Think about what a fingerprint on glass looks like, no more.
    Thats the correct amount.
    Press down on the lid of the container to release the lid.
    Vacuum out the game and playfield to remove all the white dust.
    3 weeks later
    #1962 2 years ago
    SAFE CLEANER FOR ANY GAME, AND ESPECIALLY OLDER GAMES
    So we now know what cleaners to avoid for older games, so what's a good cleaner we can use?
    Our old friend Naphtha.
    It's cheap ($14 a gallon), it removes old wax, it won't swell wood, and it won't remove solid paint or topcoat.
    Naphtha is flammable (it's the stuff you use to refill a cigarette lighter), so don't throw dirty rags on the floor next to the hot water heater. Spread the rags out flat and let the Naphtha evaporate until dry.
    Again, don't "clean" just to have something to do, but wait until you see how black the rag comes back after wiping an old, porous playfield down with Naphtha.
    vid1900 someone today challenged me on suggesting naphtha for regular pinball playfield cleaning vs Novus 1&2. The attached image is their claims.
    I’ve only been maintaining pinball machines for about four years. But I use your advice and guides as gospel.
    I just want to double check that I didn’t misunderstand you.
    In your (or anyone else’s) experience, is this person correct that it will quickly thin and ruin the playfield clear if used regularly? (A couple times a year).
    6AC73D1D-B203-4496-8244-A6E6DE44E5D1 (resized).jpeg6AC73D1D-B203-4496-8244-A6E6DE44E5D1 (resized).jpeg
    #1963 2 years ago
    "Quickly strip a PF Clear"...um no; another internet freak out.
    And if we're talking aboot modern games you own, you couldn't take that clear off if you dipped
    It in naphtha and lit it on fire.
    #1964 2 years ago
    Quoted from TheLaw:
    Those comments about not using Naphtha probably came from a person who is happily using Magic Eraser and alcohol to ruin their playfields. Ouch, and I know there are a lot of fans here of ME. Quietly waiting for the down votes
    12
    #1965 2 years ago
    Quoted from dashv:
    Tell the idiot that luthiers use Naphtha to clean centuries old musical instruments all the time.
    The reason that they use it is that it DOES NOT remove the old finish.
    I've had this 1959 Gibson for 40+ years, does it look like Naphtha has 'stripped the finish' in any way?
    #1966 2 years ago
    Quoted from dashv:
    This is what I would call, HOGWASH...
    #1967 2 years ago
    And, there’s no dimpling on that old Gibson which just PROVES that playfields today are made from softer wood and thinner clear.
    #1968 2 years ago
    Just started to read this! Great info so far!
    #1969 2 years ago
    Quoted from Nokoro:
    Yeah, it's said that the Maple tops on those 50s Gibsons were Old Growth Maple, over 200,000 years old.
    The sap from them is so hard that when you tap them, pellets of sap fall into the bucket like a slot machine jackpot.....
    #1970 2 years ago
    vid1900 I hope you don't mind me dropping a link here. I made a video demonstrating Novus 3,2,1 and Naphtha on an old plastic cassette case I was cleaning up. It's very similar materials to pinball ramp plastics. I talk about Novus 2 and 3 being abrasive and demonstrate it on the plastic.
    I though it would be relevant to share here because I learned about Novus and how to appropriately use it from this thread. So I made this video to illustrate what you describe in action.
    #1971 2 years ago
    Picked up this pin in 2013. It's the original playfield and believe it or not with just three coats of wax on it. Will have to try the Blitz wax now that I found this thread.
    #1972 2 years ago
    So, if just cleaning, vacuum and clean cloths but if it is time to wax use naphtha to clean the old wax off first?
    #1973 2 years ago
    Don't use naphtha unless you want to strip all the old wax
    Normally, you leave the last wax, and just freshen with a new coat
    #1974 2 years ago
    Thank you!
    #1975 2 years ago
    I have a brand new machine with about 600 games on it also my first machine. Should I use naphtha to get the light marks from the balls out of the playfield before waxing it ?
    #1976 2 years ago
    No. Please read the posts directly above yours.
    #1977 2 years ago
    Quoted from Black_Knight:
    Don't know how I didn't see that. So what should I use?
    #1978 2 years ago
    First, take the time to read this thread.
    Second, do what it says.
    #1979 2 years ago
    Quoted from McIntyre905:
    Are those scratches in the clear? If so, replace your balls. They may be pitted or chipped.
    Some amount of clear coat scratching happens over time which is why it is important to wax regularly to make that sacrificial layer.
    If not scratches, does it wipe up with your finger? Does it seem oily? You could try naphtha to see if it goes away. Perhaps you didn’t clean your balls of the oil before you put them in the game?
    #1980 2 years ago
    You don't need naptha according to this thread. Novus 1 and real carnauba wax.
    #1981 2 years ago
    Quoted from Nokoro:
    I'll take a better look at it when I can tomorrow. Unfortunately this is my first machine and I had someone who apparently knew how to install machines but I know I didn't see him check the balls before putting them in (and I didn't know you are supposed to) so I'm really hoping I can get this out. Its brand new only like 500 plays
    #1982 2 years ago
    Novus 2 will smooth out the scratches,
    Blitz 1000 or P21S (silver can) will protect the finish.
    When applying wax, less is more. Its not Spackle...
    A proper coat should look like fingerprints on glass.
    Let it dry thoroughly, then wipe off , then buff with a flannel (yellow) rag.
    Vacuum out the cab and any remnants when your done.
    Let it dry a bit, you should be good.
    You cant build wax coats, its impossible, one is enough.
    A lot of people skip the vacuuming.
    Get a small shop-vac (1.5 or 2 gal) They are really handy.
    https://www.walmart.com/ip/Hyper-Tough-1-5-Gallon-2-0-Peak-HP-Utility-Wet-Dry-Vacuum/255414349?wmlspartner=wlpa&selectedSellerId=0&wl13=5864&adid=22222222277255414349_117755028669_12420145346&wmlspartner=wmtlabs&wl0=&wl1=g&wl2=c&wl3=501107745824&wl4=pla-293946777986&wl5=9030872&wl6=&wl7=&wl8=&wl9=pla&wl10=8175035&wl11=local&wl12=255414349&wl13=5864&veh=sem_LIA&gclid=Cj0KCQiA9OiPBhCOARIsAI0y71C_lgsgBqmCHZg0m7osXI_77HQH_OabTmhj8j8HD_GNnpfw3nuZhLwaAuGHEALw_wcB&gclsrc=aw.ds
    Store it under your game.
    #1983 2 years ago
    Quoted from pinballinreno:
    Thank you I appreciate it. I did try a do a bit of cleaning but was still waiting for my Novus so I did apply a bit of wax. Should I use Novus 1 first and see if I can get them up before going to 2? Should I try and remove the light wax I did ?
    #1984 2 years ago
    Novus 1 is basically worthless.
    Its windex with a very tiny bit of wax in it. It wont do anything at all.
    If your talking about clearcoat wear, Novus 2 to buff off scratches, clean all of the novus off with a little naptha or sparkle on a rag., then wax.
    I use mist n shine for cleaning between wax jobs:
    https://www.amazon.com/Wizards-Detailing-Showroom-Chemicals-Mist-N-Shine/dp/B002U729UA/ref=asc_df_B002U729UA/
    I use naptha on a q-tip to clean post rubber sleeves, rubber rings and targets.
    #1985 2 years ago
    What's the difference between P21S and S100? From what I can tell, the S100 is half the price. And is there a difference between the P21S with the blue cap versus the silver cap?
    #1986 2 years ago
    Anyone using Pinheadz black ops? I have been using it for awhile now and have good results with it.
    #1987 2 years ago
    Quoted from unclerudy:
    P21S silver is pure carnauba whereas the blue cap id diluted with beeswax like so many others.
    #1988 2 years ago
    Any Canadians know where to get Naphtha
    #1989 2 years ago
    Ronsonol Branded lighter fluid at a local store? Its perfect.
    This is the also the real thing:
    "Recochem" Camp Fuel sold at Rona. The SDS for it says 100% Naphtha
    Coleman fuel is pretty clean and works good in a pinch:
    https://www.canadiantire.ca/en/pdp/coleman-fuel-naphtha-0760044p.html
    #1990 2 years ago
    Vid, do you recommend waxing new or used balls when doing periodic cleaning?
    #1991 2 years ago
    Quoted from Gotman:
    I de-oil new balls with Brake Kleen (or whatever $2 brake pad cleaner I have around), then if you want to wax them, you can just use the dirty wax rag you waxed the playfield with
    Even if you don't wax them, they don't seem to rust any faster than waxed
    Used balls obviously don't need to have oil removed, just wipe them off and make sure they don't leave a brown rusty residue on the rag. If they are no longer mirror finish, replace
    #1992 2 years ago
    Is this safe to use on machines? Sherman Williams sells the VM+P Naptha but I need a contracter license to buy it
    #1993 2 years ago
    yes
    #1994 2 years ago
    Great info everyone
    #1995 2 years ago
    Quoted from smoothbore19:
    IMO, cleaning and protection are two different things. Cleaning removes dirt and wax, protection is putting on a solid coat of wax, so how can one product do both well? I'm also dubious of the percentage of carnauba or the solvent amounts in the product if it's a liquid or cream. Can't seem to find an SDS for it.
    I'll stick to Wizard Mist & Shine/Naptha for cleaning, and a straight can of carnauba wax paste for protection.
    #1996 2 years ago
    Kind of like how there is a difference between cleaning and sanitizing.
    #1997 2 years ago
    Sorry if I'm repeating a question, I haven't read all 2000 posts.
    I just tried to order the Blitz wax and online they said it's been discontinued. Substitution?
    #1998 2 years ago
    So funny, the Russian bottle next to your guitar says "vodka"
    #1999 2 years ago
    Quoted from Skybug:
    Pinball life carries it
    https://www.pinballlife.com/search.html?Search=Blitz
    #2000 2 years ago
    Quoted from Skybug:
    Yikes
    I'll have to make sure they all say горілка from now on!
    This page was printed from https://pinside.com/pinball/forum/topic/cleaning-and-waxing-pinball-machines-vids-guide/page/40 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
