(Topic ID: 137689)
Cleaning and Waxing Pinball Machines - Vid's Guide
By vid1900
6 years ago
  • 1,971 posts
  • 378 Pinsiders participating
  • Latest reply 9 days ago by Garrett
  • Topic is favorited by 1,018 Pinsiders
    5 key posts have been marked in this topic (Show topic index)
    There are 1,971 posts in this topic. You are on page 27 of 40.
    #1301 3 years ago
    Quoted from vid1900:
    Replace your balls, it should be lasting way longer than that.
    You would much rather have your wax wearing off than your clearcoat wearing away.....
    I'm using Ball Baron Ninja balls...finest balls you can buy. Same situation, every game. The wax provides no benefit to me. Makes the ball way too fast and only seems to protect for a handful of games before it wears off. Another reason is:
    It's not like anyone is wearing out clearcoated playfields, even when installed in commercial environments, lol.
    #1302 3 years ago
    Yes thats the stuff, expensive but one can of either will last a long time.
    You only use tiny amounts. More doesnt do anything and you cant build coats because each new coat melts off the old one.
    #1303 3 years ago
    Quoted from mrgregb123:
    Wax keeps the clearcoat from getting hazy too fast between buffings.
    Same with cars.
    Hi solid content waxes last a long time. Liquids rub off in a day as they are mostly solvent.
    The Ninja balls are very nice, they look almost as good as regular balls after being in the polisher for a day.
    #1304 3 years ago
    Never done any repair to a playfield before. looking at picking this up but wanted a head start on repairing the little white spots on the edges of the eye inserts. A Little flesh colored paint then??? Some kind of clear coat just on those spots or should I look at some mylar..Any input would be appreciated...
    #1305 3 years ago
    Quoted from pinballinreno:
    Others like the Blitz 1000 wax. Its also very good but leaves a fair amount of white dust that you have to vacuum off.
    You must be thinking of Bill's
    Blitz has no white dust or flakes.
    You can barely tell when it's dry.
    #1306 3 years ago
    Quoted from mymalibu:
    You can see that those inserts are moving in the wood.
    So you will need to stabilize them, paint them, then clearcoat the playfield.
    https://pinside.com/pinball/forum/topic/vids-guide-to-ultimate-playfield-restoration
    #1307 3 years ago
    You can barely tell when it'd dry.
    Perfect in the picture, Im sure I applied way too much that day.
    (always in a hurry, always screwing things up etc..)
    #1308 3 years ago
    Thanks vid ,I knew you would have the answer. I think It's a bit over my head to strip a play field and try that kind of repair. I'm ok with mechanic's and stuff but not that insert repair, not to mention the time to do it. Oh well I'll keep looking... Thanks.
    #1309 3 years ago
    You can stabilize the inserts without stripping the playfield.
    Any 30 year old game is going to probably have some loose inserts, par for the course
    #1310 3 years ago
    Fair enough, 30 years old..going to read through your insert repair guide tonight. Might have a question or two...LOL. Cheers.
    #1311 3 years ago
    vid1900, you mention earlier in this thread about drilling clear on a new playfield do you have any tips or tutorials for drilling out the holes and prepping a clear coated play field to repopulate it again.
    #1312 3 years ago
    Quoted from mmr61184:
    Vid1900, you mention earlier in this thread about drilling clear on a new playfield do you have any tips or tutorials for drilling out the holes and prepping a clear coated play field to repopulate it again.
    Would really like to hear discussion on this
    #1313 3 years ago
    Take a BRAND NEW Brad Point drill bit and (by hand) cut out the surrounding clear.
    You don't want any of the screw's threads touching and thus lifting the clear from the surface.
    There is a section somewhere in the Playfield Restoration thread, but I could not find it on my phone.
    #1314 3 years ago
    Been reading your guides for the past few weeks/months. So much valuable information I just wanted to thank you for sharing and answering questions.
    This thread is priceless!
    #1315 3 years ago
    You can also get a couple of tips on the CPR site under CPR install guides
    #1316 3 years ago
    This is the first of five "key posts" on the topic from that thread: https://pinside.com/pinball/forum/topic/vids-guide-to-ultimate-playfield-restoration/page/45#post-2611546
    #1317 3 years ago
    Our old friend Naphtha
    I don't think this question was answered but is Naphtha the best solution for cleaning the outside cabinet walls or do you recommend something else?
    #1318 3 years ago
    For pinball, I think everyone uses "light Naphtha" AKA/ Varnish Makers and Painter's Naphtha (VM&P Naphtha).
    Some other varieties are Zippo lighter fluid, and "white gas" camping fuel.
    Been combing through this incredibly insightful thread, and just wanted to clarify that Novus 1 might not be the best choice for regularly scheduled cleaning, and that Naphtha can be use more safely to clean your pf?
    All my games are HUO, but get quite a bit of use. Is Naphtha safe to use everytime my games need a cleaning? And is there is there still a point of using Novus 1? I get that for ball trails or light scratches I could bring out the Novus 2 on occasion.
    And lastly, is Blitz still the top choice for wax?
    Cheers
    #1319 3 years ago
    Almost everything that I've learned, I learned from this thread. So, take it with a grain of salt. I believe that Naphtha will remove wax, so probably should not be used for regularly scheduled cleaning, unless you are also waxing it. I don't know whether Novus 1 will remove wax.
    I believe that the thought is to use the lightest touch able to clean. So, for regular cleaning, you may be able to just vacuum or clean micro fiber cloth.
    For wax, Blitz wasn't readily available to me, so I went with Mother's Pure Brazilian Carnauba Wax (item 5550) (NOT the cleaner wax which is item 5500). I think the key points for wax are: no abrasives or cleaners; and no silicon or synthetic waxes.
    #1320 3 years ago
    Quoted from Damien:
    Cheers
    Naptha (lighter fluid) is hard to beat for degreasing and dewaxing. And its way cheap.
    But it can be smelly. But its waterless, and thats important on older games that might have some bare wood showing or cracks in the clear.
    Right now I like Mist n Shine on the new games (its what JJP uses on the line). Its a detailers quick clean product and looks great on clearcoat. Also way cheaper than novus 1.
    I use it for between waxing cleanups. It has some wax in it and smells great.
    I use novus1 on plastics after they are cleaned up. I think it shines better than the mist n shine. Mist n shine has a higher wax content it looks a tiny bit duller on plastics but still works good.
    Other than that, I use sparkle glass cleaner on tons of stuff (even black dust). It wont ruin coated (Anti-glare) playfield glass or melt plastics or posts (unlike 409 this crap is deadly)at all. And its also a pretty good, mild cleaner of itself.
    #1321 3 years ago
    Is this the product you're referring to:
    amazon.com link »
    And is it advised to use this every month or two when I clean my games before waxing?
    I'm still a bit unsure of why and when I'd need Naphtha. If I'm already cleaning and then waxing with something like the above product, why would I need to use it?
    Also, what's best for ball trails, ball swirls, and light scratches? Novus 2?
    #1322 3 years ago
    Does it make sense to wax a clearcoated playfield. I have heard some people say it makes the ball fly too much and that the clearcoat these guys would take years to tear up in a home environment
    #1323 3 years ago
    Exactly what I was thinking with my old woodrail which has cracks revealing bare wood.
    Does the smell go away with fan and open window? A smelly game wouldn't be good.
    #1324 3 years ago
    Quoted from Damien:
    amazon.com link »
    Yes thats the stuff.
    Maintenance has more to do with games played than time.
    I do a wipe down, general cleaning and black dust removal every 250 games.
    I do a wax job in all the areas I can reach every 350-450 games.
    I do a full cleaning/ball track removal/wax removal with naptha and partial tear down when I replace the rubber, every 3000-5000 games. Sooner if the game isnt being played much and the rubber is drying out. Like car tires, I think the rubber dries out less if its being played.
    For me at least the rubber is getting replaced every 3 years or so depending on how it looks and plays. And of course when a piece breaks.
    Others might have a different schedule, but this works for me.
    Ball tracking/swirls and wear areas is easily taken car of with novus2. Go easy on this stuff and rub gently. Its an abrasive and will thin down the clearcoat in time.
    Always wax over the area you used novus2 on after the area is clean.
    Its best to clean off the ball tracking as it occurs. Often it will come up with wax or a cleaner. Leaving it on a long time will bury the grit into the clearcoat.
    #1325 3 years ago
    Al games, all cars, everything with clearcoat should be waxed they will look nicer much longer.
    Just use a 100% carnauba past wax not a liquid.
    You dont really want to wait until the clear is so dirty that the grit is embedded into it.
    Its better the let the grit set into the wax instead of the clearcoat, remove the wax with grit in it then re-wax.
    Its true that the clear will last a long time. But ball wear areas will need a renewable coating to help the clear last its longest.
    Its simpler to just wax the areas you can reach periodically.
    The playfield will thank you later.
    #1326 3 years ago
    Ahh makes sense thanks. They suggested to use mothers quick spray if anything but sounds like that’s no good.
    #1327 3 years ago
    Quoted from PinballFever:
    As always, you have to ask:
    "What are you cleaning from the outside of your cabinet?"
    #1328 3 years ago
    Quoted from Damien:
    Naphtha will de-wax your playfield, so you probably don't want to use it all the time.
    What has gotten on your playfield that you might need Naphtha to remove?
    Quoted from Damien:
    Most the time, you can just vac and re-wax.
    #1329 3 years ago
    Finally product meant for Pinball that contain what we have all been asking for! Carnauba wax, UV protectants, and playfield safe cleaner. www.pinhedz.com
    Available at
    www.pinballpro.com
    www.thepinballwizard.net
    www.mezelmods.com
    www.tiltgraphicsinc.com
    #1330 3 years ago
    I love this thread and I love all of Vid's tutorials but I think I am more confused now then I was before, mostly about waxing. Between all of the conflicting opinions and I expected that but i think i am just overwhelmed
    #1331 3 years ago
    anyone have any tips for cleaning orbits without taking ramps and such off? There doesn't seem to be too much discussion of that. What tools do you use?
    #1332 3 years ago
    Quoted from FatPanda:
    Couple options - for areas that need some elbow grease, a relatively thin microfiber cloth w/naptha + a long PLASTIC (nothing than can scratch) wand or other long pointy tool that you can push up and down along the hard to reach areas like orbits.
    For areas that don't require elbow grease and/or applying wax, a foam brush (pictured) works great. Awesome for inlanes/outlanes too so you don't get wax/cleaner everywhere.
    For just vacuuming, that awesome mini vac attachment set on Amazon can't be beat and can reach practically anywhere in most games.
    #1333 3 years ago
    I'll have to scour my local Menards/Home Depot for the plastic rod/wand, unless there is something specific you use? Was thinking something with a microfiber cloth wrapped around it with rubber bands that can get pushed into the orbits. I've got a Dyson cordless mini-vac that works well for vacuuming.
    Do you do this for waxing also? Or do you do a partial tear down?
    -2
    #1334 3 years ago
    Vid will hate this but I do not wax my machines. I keep them clean religiously with vacuuming and naphta but because naphta removes wax, it would be a huge burden to have to keep waxing them. Plus waxing makes the ball travel way too fast.
    #1335 3 years ago
    Think about it’s purpose...
    Wax does two things. It’s a filler and a sacrificial layer of protection. The wax fills in the pits in the surface making it smoother and will wear less because of that. Second, it coats the entire surface in a soft but reasonably durable layer that also reduces friction and hence wear on the surface below. Over time, that coating breaks down... and can collect dirt itself too. That’s why over time you clean it up and reapply.
    So for older more rough surfaces... wax is pretty helpful. On a modern glass smooth clear coat it has less jobs to do... plus the clearcoat is very durable itself. So it’s less needed. But the wax can still be used to be that sacrificial layer. Just sometimes people feel it can play too fast. It can always help... it just has the potential for too much speed and of course more work.
    In home play, most clearcoated games won’t see the amount of cycles to say “always wax it!” To avoid premature wear. So it’s not mandatory... but it’s helpful.
    On older games with just lacquer topcoats, the sacrificial barrier wax provides is much more helpful.
    On material to use... the principal is simple. You want wax only and less of other shit. Cleaning waxes are polishes plus wax. You just want a wax. Liquid waxes are wax plus solvent to make it soft. You want a harder wax that is more durable.. so no liquid wax. Pure wax is hard... so you need something to soften it.. and that’s where the paste waxes are used.
    The other category is the polymer coatings that are liquid... they aren’t wax, but do a similar job. They are formulated to layer on clearcoats
    #1336 3 years ago
    Right now I use some old wooden spoon handles and a couple rubber spatulas trimmed to fit in some tight areas.
    I have a couple old spoons that I let soak outside in a bucket of water for a couple months (I forgot about them) and they warped into gentle curves. I think that I could warp some specially for cleaning tools but I havent had to do that yet. If they get too rough I just sand them a little.
    I just wrap either a terry cloth towel or a yellow felt cloth depending on the job.
    Sometimes I just push thru a wad of paper towel dampened with whatever cleaner seems proper.
    And of course either old or new toothbrushes to clear out cracks and the occasional waxey goop on a star post.
    Lastly I really like RC-88 rubber cleaner.
    Its mean stuff but works wonders on rubbers. It kills black dust on contact with a q-tip.
    Dirty rubber can look like new if cleaned with this stuff, especially the white ones.
    Just dont use it on anything else but the rubber or non-decaled stand-up targets.
    #1337 3 years ago
    Quite interesting. I'm thinking something flexible that can bend around the curve, but be sturdy enough that I can put a bit of pressure down towards the playfield to clean.
    #1338 3 years ago
    I havent found anything flexible that I could put enough pressure on to do a light scrubbing.
    But wooden spoons can be bent to any shape after boiling, steaming or soaking for a long time.
    They are super cheap and they come in a lot of shapes, lengths and widths.
    I buy them by the bag once in awhile at the dollar store, especially if there is a new shape I might use.
    They can also be cut and trimmed to whatever you want to use them for.
    I imagine some 1/4" and 3/8" dowels of assorted length would be similar but no flattened ends for rags attached.
    #1339 3 years ago
    There are no conflicting facts.
    FACT: Paste Carnauba wax protects the playfield from wear.
    FACT: Steve Ritchie tells you to wax your playfields so they play how he designed them to play.
    #1340 3 years ago
    I second Mr. Tantrums California Gold Carnuba Paste wax from Mothers suggestion. Works great and even smells pretty nice.
    #1341 3 years ago
    Quoted from gunstarhero:
    This is a pretty good cleaner wax.
    It has more solvent than I require though.
    Right now I just clean off the old wax then apply a very high solids pure carnauba like blitz or P21S.
    I like the outcome better and the non-cleaner wax seems longer lasting and harder.
    -2
    #1342 3 years ago
    You're saying Steve Ritchie designed his games for environments (i.e. route operation with nicely waxed pfs) that would never actually exist? Not sure that's entirely true:
    Wax it with a good carnauba car wax. It must be done carefully. Don't get the wax down in holes or on parts you don't want to wax. It works very well and will help keep your playfield nice. Take care and enjoy! Steve
    Looks like he recommended it to keep the playfield nice, and nothing more. God, I hope no designer actually designs a game expecting the pf to be waxed.
    #1343 3 years ago
    It would be ludicrous to imagine that one would design a game that would only play correctly if it was dirty or worn out.
    One can only design around new games and ones that are waxed and play like new.
    Designers are paid to make "New" games, not old dirty, crusty ones.
    #1344 3 years ago
    100% true.
    Every successful route operator waxes his games.
    #1345 3 years ago
    Not going to go on and on with this so I'm cutting out after this but "like new" and "waxed" are not the same thing. "Dirty or worn out" is not the opposite of "not waxed". Every machine in my collection has a PF that is "like new" but none of them are waxed. I've purchased NIB games from JJP, CGC, and Stern. None of them arrived with waxed playfields. Look, you want to wax your PF in a home environment where it's totally unnecessary, have at it. But to imply that designers craft the game with this is mind is ludicrous.
    #1346 3 years ago
    Think how many times you go into a truck stop while traveling and there is a TAF next to the Galaga/Pacman and keyhole machines.
    You look and see that some of the GI lights are out, and the playfield is dirty along the edges.
    Even being a pinhead, you won't put $1 into that machine, because you just KNOW that the flippers will be weak and some of the targets won't register.
    Dirty machines don't make money.
    Now let's change that scene to a machine with a waxed playfield (the wax repels dust from accumulating around the edges) and 100% working GI. While your wife and daughter are shopping for cheap t-shirts and waiting for their Chinese Express food, you KNOW you will play that game; even if you have it at home.
    #1347 3 years ago
    I struggle with this a bit. I wax my playfields (with Blitz). Perhaps it's my eyesight, and perhaps it's because these are home use machines that I'll hit up every few months, but it's really hard for me to see what is waxed and what needs cleaning. I feel like it's all pretty clean save some rubber dust.
    What would be a simple test to determine there is enough wax on the surface, or if the wax should be replaced entirely?
    #1348 3 years ago
    Stern waxes their playfields before they are even populated.
    Take the tour and watch.
    #1349 3 years ago
    Totally agree with you my man! No arguments there. Clean machines get played. But I think this conversation revolved around waxing for home use, which having done it in the past, I realized was unnecessary. If you're putting your machine up at TPF or Pintastic, hell yeah you should wax it - armor the crap out of it. But for home use, ESPECIALLY on machines with a nice thick clear coat, I found the ball speed makes it an overall negative. My TAF clearcoated with PPG is so friggin' fast w/o wax it would be nearly unplayable with a coat on. But you've mentioned scenarios where this makes sense - older games especially. No qualms there.
    Quoted from jsa:
    That's the other problem I had with waxing. Wax with Blitz exactly as Vid has instructed. Run your finger. Smooth as butter. After 10-20 games the playfield feels like it did before you waxed. Your results may vary.
    #1350 3 years ago
    Quoted from jsa:
    https://pinside.com/pinball/forum/topic/cleaning-and-waxing-pinball-machines-vids-guide/page/4#post-2661845
