Ok gang I'd thought I'd list out the products I like to keep on hand in the shop. Im sure folks will have more to add to the list.
1st from left
Wipe on poly from millwax, good for touching up siderails on pf as well as top arch. Can soften the look of flipper drag on a pf.
spray adhesive, reattaching certificates to top arch on GTB
TitebondIII wood glue for all those cab joint reglues. Also reattaching labels to bottom board etc
Brakleen, good for degreasing steppers etc
Simple green, all around cleaner, cabs, pfs, light grease etc
millwax, pf cleaner and "wax"
Windex, clean that pf glass!
Kwikwood, 2 part wood epoxy for filling in those large cabinet booboos, more better/harder than bondo, doesnt shrink
H20, used with 400 grit wet/dry sandpaper when regraining the siderails
lacquer thinner: cutting Krylon webbing when respraying with a HF touchup sprayer
alcohol 91% pf cleaning etc
2nd pic
Gorilla 2 part epoxy. regluing factory joints in cabs
Gorilla super Glue, lots of uses, gluing cab feet on to the bottom/butt of cabs
Loctite rust dissolver, rust cleanup on chrome pieces
Novus 2 pf cleanup
Purple Extreme, synthetic lub, bought for my bike chain, use it on stepper spindles etc
novus 3, polisher, use it to polish shooter knobs with steel wool etc
bondo, small cab fixes before repainting
novus 1, plastic cleaner
wd40, unsticking stuff (no flames please )
super lube, lubing steppers, as relays etc
bowling ally wax (Boilerman rec) for shining up those beautiful WK repro pfs
Motsenbockers paint remover, removing that nasty latex overpaint on the 60's wedgeheads
Shellac sanding sealer, a super primer for non veneer cabs, helps to give a smooth paint finish.
Others?
