Elektra has been working decent, sometimes I can play, sometimes it doesn't want to boot. More often than not it works
Tonight I decided to clean and reseat all the socketed chips on the logic board to see if that helped. Some of the bottom few chips had especially dirty legs, I got everything shiny new looking and reinserted and checked the replacement battery and it was dead. I checked the new battery, 1.51 volts and inserted it. I checked it at the board and it was only 0.6 volts. That's when I noticed the new battery I just put in was warm so I took it out immediately.
Now it boots up like normal but before it finishes saying "you have been exposed to Elektra's radiation, will you return?" it starts cycling through the test menu and nothing I do stops it. Once it gets to the end of the cycle it resets and does it again over and over. The test button was testing always on so I disconnected it, no change. Tested button out of circuit, works fine.
There were spliced wires in the coin door where the coin switches for the left and middle should be so I cut them, no change. It was recently saved from a shed and spent a long time as home use only. It's always been on what I thought was free play but the credits always show a hard to read "40" as shown in the video
I just reflowed the pins for all the connectors yesterday and it worked normal after that. I'm stumped, could I have done something cleaning the chip legs to short something and that's why the battery got hot?
