(Topic ID: 144550)
Clean Old Wax(?) Residue Stuff Off Posts
By Wickerman2
8 years ago
  • 33 posts
  • 16 Pinsiders participating
  • Latest reply 8 years ago by o-din
#1 8 years ago
I am ready to just buy all new posts...tried ultrasonic, scrubbing by hand...simple green, krud cutter. Seems like after I ran them through the ultrasonic it made this stuff worse(?). Is there any easy solution here? I have already spent way too much time trying to clean these. I have 20-30 in this condition. I can scrape it off with my fingernail but that seems a little absurd for the amount I have to clean.
#2 8 years ago
that stuff is what remains after the oil is gone from the plastic. imho, they are done.
A small hole in the back yard with a tiny cross is in order.
others may have a solution, but I have not hurd of it.
#3 8 years ago
I saw your post in the other thread. That looks like the cleaning agent etched (ate through) the glossy plastic surface.
#4 8 years ago
Quoted from Skins:
If you scrape it off, there is glossy surface under it, it's on the surface.
#5 8 years ago
And it's spreading but not permanent? Weird.
#6 8 years ago
if you can scrape it off, and glossy still under, maybe try a stiff tooth brush and mild soap?
still lots of work, and no guarantee it will last. I would go with new ones at this point...if you can find them.
#7 8 years ago
Give them a good peroxide bath. Put in a ziplock bag, set in the sun for 3-4 hours.
#8 8 years ago
If it is just an old chemical film. Wash them with a brush and hot water. Then to get them looking their best wipe or polish them with Novus 2. Going by your statement that it can be scraped off.
#9 8 years ago
I think the ultrasonic baked this scum on there. It will scrape off with a fingernail, it buffs off with a really abrasive pad with some work, the toothbrush doesn't work, I'll soak one in some peroxide to see. I have 52 of them, so $26 worth of posts if I replace...going on a game that isn't collector condition so I was hoping for an easier DIY. $$ not a big deal, just seems like there should be some easier method here.
#10 8 years ago
A really simple tool for getting old wax off jewel posts is a toothbrush. From my own personal experience, a toothbrush gets all the old wax off, and you don't even have to remove them from the game. Vacuum up the dust, and you're done.
#11 8 years ago
Quoted from PNorth:
That ship has sailed...I think the ultrasonic baked it on. I like to take everything off the playfield to make it easier to clean/wax either way.
#12 8 years ago
Forgot--I also ran them through a cycle of the dishwasher to see if that would loosen that stuff up.
#13 8 years ago
#14 8 years ago
Quoted from swampfire:
I have that same faucet.
#15 8 years ago
That might have worked before the ultrasonic created some sort of molecular super bond...I toothbrushed the hell out of 1 and it didn't do jack. I don't have tire cleaner(?) but I did try simple green and Krud Cutter. That technique looks like the way to go in the future...since I had 52 posts I thought the ultrasonic would work great!
#16 8 years ago
I'd just buy new ones (a hour of your time has to be worth $25), but if you are strapped, then hit them on the buffing wheel with some compound.
#17 8 years ago
Quoted from vid1900:
I'm more impatient
At this point I've already wasted way too much time but I can't let these posts win. I have a list filled out for PBR either way--just seemed like there should be a reasonably easy way to clean them, instead I've made them worse!
#18 8 years ago
I hit one with a buffing head on a dremel and it actually took away plastic before it cleaned this stuff. The only sure bet is my thumbnail so PBR will get an order I guess.
#19 8 years ago
I don't think that stuff is old dried wax. And I've never had any luck with getting it off once the posts develop that plague. The plastic has leached something.
#20 8 years ago
Quoted from DirtFlipper:
52 x C11561W posts Steve
#21 8 years ago
Buy new.
#22 8 years ago
Quoted from Wickerman2:
Good. Now just add new plastics, pops, skirts, caps, flippers, bulbs and rings and you'll be all set.
#23 8 years ago
Where do you get the new posts from? I looked at a few places and did not find the ones I needed.
Blue for EBD and there are two different sizes. Thanks
#25 8 years ago
Noooo!!! This game is a beater which is why I was trying to save the posts...bulbs all good, plastics all good, pop is fine, flippers have a nice "patina"....and the playfield has a nice array of planking
#26 8 years ago
You could paint hem w/Krylon plastic paint....another option.
#27 8 years ago
I have both Wesley Bleche-Wite and a slew of "infected" posts that I replaced on my Domino ('68). The posts were not previously cleaned; I just removed them from the playfield. I chose two posts that were nearly identical and soaked one in the Bleche-Wite for 20 minutes. I used a toothbrush and almost scalding water to clean the post. Here are the results.
The clean one is on the left. FYI.
#28 8 years ago
Actually, I need to update that video. Nowadays I use Simple Green, hot water and an old ultrasonic toothbrush. The toothbrush and hot water do most of the work.
#29 8 years ago
They are like $0.30 each?
#30 8 years ago
It's not just a question of cost. A brand-new post can look "off" in an old game, and sometimes it's impossible to match the color and style. I bought a bag of red finned posts a decade ago for Black Knight, but they were cherry red instead of dark red - looked totally wrong. I finally got to use those in Skateball, but Black Knight has its original dark red posts.
#31 8 years ago
I had this happen to some pop bumper caps I put in an ultrasonic, weird.
#32 8 years ago
Quoted from Msch:
.50 each. Spanking new bright whites will look a little off on a 46 year old game, not a huge deal to me on this particular game though. I am ready to put it back together and now I have to wait another week to get the posts...that's more the issue with me
#33 8 years ago
Try here. I'm sure somebody has a hoard of decent used ones.
https://pinside.com/pinball/forum/topic/the-em-seeking-parts-thread/
This page was printed from https://pinside.com/pinball/forum/topic/clean-old-wax-residue-stuff-off-posts and we tried optimising it for printing. Some page elements may have been deliberately hidden.
