(Topic ID: 298163)
Classic Stern Sling Blows Transistor
By seshpilot
2 years ago
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 2 years ago by seshpilot
#1 2 years ago
I'm stumped. The left sling on my Quicksilver keeps blowing the transistor the second the ball hits the target. Using the correct coil (with no diode, just the one on the right), the diodes (IN4004) on the switches are not blown, and everything appears to be wired up correctly. It doesn't blow until the switch is hit, but then the coil locks on. What's my next step?
PS: top pic shows diodes cut so I could test them w/multimeter
IMG_7559 (resized).JPGIMG_7559 (resized).JPGIMG_7560 (resized).JPGIMG_7560 (resized).JPG
#2 2 years ago
Quoted from seshpilot:
Some Williams coils like yours don't come fitted with diodes. They are a must in these Stern games. The missing coil diode is the reason the transistor keeps blowing. The banded side of the diode goes on the yellow wired coil lug.
#3 2 years ago
Quoted from Quench:
Thanks man. I’ll try that out. What’s word is that the right sling doesn’t have one but is working just fine! Why is that? And is a IN4004 ok?
#4 2 years ago
1n4004 is okay. Every coil in a classic stern should have a diode on it
#5 2 years ago
Is the right coil being driven by a different driver (model) transistor?
When the driver transistor switches off and disconnects power from the coil, the coil has stored energy which comes out as very high voltage in reverse direction whose path goes across the driver transistor. This high voltage is beyond the spec of the transistor so it blows. The purpose of the diode on the coil is to clamp this high reverse voltage to a negligible level. The phenomenon is called "back EMF".
In this video, you can see when the user opens the switch, the back EMF from the large coil releases into the lamp causing it to briefly illuminate very brightly.
#6 2 years ago
Yep, that fixed it! Thanks. I put one on the right sling too just in case.
$ 189.00
Beehive Pinball Co.
$ 12.00
Third Coast Pinball
5,800
Spring Grove, IL
$ 959.00
$ 859.00
$ 12.00
7,500 (OBO)
Sandusky, OH
Various Novelties
Pinball Photos LLC
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/classic-stern-sling-blows-transistor and we tried optimising it for printing. Some page elements may have been deliberately hidden.
