Classic Stern Insert Lamp Out
By brianmcculloh
6 months ago
Stats
  • 4 posts
  • 3 Pinsiders participating
  • Latest reply 6 months ago by brianmcculloh
Find
Search this topic for posts matching certain words or written by a specific Pinsider. Or both!
#1 6 months ago
In the process of retro-fitting my #Flight2000 with the LED lamp adapter kit, I have lost 2 of my insert lamps. I replaced the lamp sockets and the bulbs but they are still out, telling me the issue is probably closer to the lamp board. I have a multimeter but I don't know where to start to troubleshoot this.
Also of note: when removing the LED adapter kit and re-adding it again, I noticed both lamps came back on along the way at some point, but now they're off again. What should I test to see where the fault is?
#2 6 months ago
wiggle the connectors on the lamp driver board , could be a cold solder joint or a bad trifericon pin
#3 6 months ago
Sometimes it is the simple things that are the problem and often overlooked. The connectors could be failing, have cold solder issues or the like. I would start there. If they check out, only then would I break out the dmm and start checking traces, diodes, scr's etc.
http://www.pinwiki.com/wiki/index.php?title=Bally/Stern
#4 6 months ago
That was it - just a loose connection. I really wiggled a lot of the connections till it finally came on. Might have actually been a wire too, thanks guys!
$ 7.65
Cabinet Parts
Third Coast Pinball
$ 19.95
Note: This is an old thread. The last post was made to it 193 days ago. Resurrecting old threads is not necessarily a bad thing, if you think the topic is still relevant and/or your post is beneficial to it (e.g. following up on something). In other cases, it might be better to create a new topic.
Wanna join the discussion? Sign up for a Pinside account, or log in if you already have an account.
