Quoted from zacaj:I wonder if there's enough market for repro SB-100s... It seems a lot of people have trouble with them and they're almost impossible to find if you need one
There is great demand for SB-100 boards. I get people responding to my SB-100 sales adds that sold years ago asking if I have more. I am always looking for SB-100 sound boards to buy, fix, and resell. SB-100 sound boards have high failure rates. When i fix them, i find problems in many different areas from logic to blown amps, bad caps, etc... One thing people always overlook is the AC cap used. The says schematic says putting two polarized caps in parallel is OK.... but it is not. You have to put two 470uF in series - + + - or + - - +.
I kicked around the idea of reproing SB-100 next, but the hand assembly is a killer. I did the Bally -51 sound board, prototype works a treat, and have enough parts to assemble 20 of them, just actually doing it by hand sucks. I might be more worth my time to buy dead sound boards and rebuild them.
Also... Bally left TTL gates inputs floating all the time it looks like. I ran across it in the -51 sound board. I guess in most cases it is fine, but bad practice. The 74154 should have pull ups on the driver board since it is selected low, otherwise you are just asking for problems if driver j4 floats. Does 74LS154 have internal pull ups and HCT does not i am guess. Kinda makes sense. The 4000 series stuff needs pulls up/down usually after the nvram nand gate debacle of 2015.
Andrew
