OK. Here is my latest. I had that steel rod in the wrong hole. With the rod now in the correct position, it holds the targets stable as the coil pulls the finger in and the steel rod makes the targets drop. I deleted my original post because it was junk.
Both rods lock into the drop target frame using 2 "C" clips on one end only. On the other end, both rods are just floating in the holes. Somehow my assembly worked with the steel rod installed incorrectly. Beats me.
Why one rod is brass and the other steel is a puzzle that I am clueless about.
Quoted from chuckwurt:Your rods are oriented differently than the 9 ball mech above. I assume yours works properly in the game?
Where can I get another rod for this bad boy?
Both of these rods each have a pair of grooves for the "C" clips to lock then into the frame. The reason only one end locks in is because the other end has the coil sitting in the way.
I think you are going to have to hire a local machine shop to make you a steel rod to match your brass rod because both of those grooves have to be there---and I consider these grooves to be close tolerance measurements. Hopefully you can find a price friendly machine shop.
You might. and I stress "might" be able to buy this 5-bank pivot shaft from Marco and if it fits in the frame holes, perhaps a machine shop can just cut in one extra groove like what is on your brass rod. But I am not a trained machinist, so no real clue.
https://www.marcospecialties.com/pinball-parts/2A-225-5
I would be lost without pinside where collective minds can figure things out.
