(Topic ID: 180730)
Classic Skeeball 10' dimensions
By animesuperj
2 years ago
  • 5 posts
  • 5 Pinsiders participating
  • Latest reply 2 years ago by nephasth
    There have been 7 images uploaded to this topic. (View topic image gallery).
    #1 2 years ago
    I've been searching a bit and am having some trouble finding dimensions of a classic 10' skeeball. Does anyone have the largest L - W - H of the sections taken apart, so body and lane? Also, how much does the body breakdown? I know the nets will come off, but does the top score panel come off as well? I know it's a long shot, but I want to see if one can be moved in a minivan. I'm hoping with it in it's smallest pieces, I'll be able to squeeze it in. Added a picture of the machine in question.
    #2 2 years ago
    The lane can be separated from the cabinet. Supposedly, there's a few bolts that hold it together (I haven't taken one apart myself, though). You'll also need to disconnect the connectors that go between the cabinet and the lane.
    #3 2 years ago
    I have moved dozens of them and from memory 10' machine will have an alley length of almost exactly 7'. Alley & head are both just under 30" wide if I remember correctly. Head stays in one piece that is under 7' tall even with the light and the depth of the head is 36" with alley removed.
    It should fit into a mini van but it really just depends on size of the mini van.
    Typically I can break one down or put it together in about 15 minutes. One bolt on each side for the net, once net is removed 3 or 4 harnesses to unplug and wires will be disconnected. Then for the tricky part - if you have never moved one - at the top of the alley where it hooks to the head there is a bracket with two 7/16" head bolts in it that holds ball count switch. Remove those two little bolts BEFORE you try to get alley apart and remove the bracket & switch.
    Then lay under the machine and you will see two bolts holding alley to head. Normally I toss a milk crate with a couple boards on top under the head/alley connection to support head & alley while I remove the bolts. Take the two bolts out - pull alley apart a little & slide hardnesses towards the head & then remove the alley.
    #4 2 years ago
    I used a 9" UHaul Cargo Van to bring home my 10' Skeeball and there wasn't even much room to spare. I would just go with a trailer/cargo van for peace of mind. These are pretty awkward to move to begin with, never mind having to cram it into a minivan.
    -Doug
    #5 2 years ago
    The 63" measurement on the back box is with legs removed.
    $ 29.99
    $ 999.00
    Medisinyl Mods
    $ 92.00
    $ 87.95
    $ 39.00
    Sparky Pinball
    $ 200.00
    Professor Pinball
    $ 2.50
    Doc's Pinball Shop
    $ 19.95
    $ 49.00
    Operation Pinball
    € 4.95
    Multigame
    $ 89.95
    $ 169.00
    Lit Frames
    $ 69.99
    $ 19.00
    Chrome Candy
    $ 299.00
    ...redshiftLED
    Bright Lights Pinball
    $ 49.99
