I finally found some time to work on pins tonight, but I could use some help with Cirqus Voltaire. The ringmaster eddy sensor stopped registering hits all together, CV uses an auto eddy sensor so it is not an adjustable board.
I've done a switch test with a ball and nothing registers. The LED on the auto eddy board does not come on or flash at all. When I remove the eddy sensor cable (two-pin) the LED still doesn't come on. When I remove the four-pin connector and place it back on the board it registers the switch #16 but still no LED.
Just in case it is related, you need to you my ringmaster magnet isn't working either, its next on my list after the eddy sensor.
This is now beyond my level of skill, any help would be fantastic.
